Old 10-27-2006, 01:59 AM
AznGuitarist112  is offline
Posts: 26  -  iTrader: (0)
RG2550EGK Question
I recently bought an Ibanez RG2550EGK, but I have a question about setting it up.
This is the first Floyd Rose guitar I have, since my other one is a locked bridge Fender Stratocaster. I want to lower the action of my prestige RG2550, but I am curious about what happens when I lower the action. Does the tension decrease when I lower the action? and Does the tension increase back up when I tune the guitar back up to normal?
OR Does the tension decrease, and I'd have to set up those springs in the back, since the action is vertical orientation and the tuning is horizontal orientation?
Thanks for the feedback.
Old 10-27-2006, 04:12 AM
GAZ  is offline
Posts: 442  -  iTrader: (0)
Re: RG2550EGK Question
It depends how much you want to lower the action by. I find a very low action great for chords not so great for string bending and not great for tone. A minor adjustment to the action shouldn't affect the string tension hardly at all, but you will be able to tell coz the angle of the trem will change.
Old 01-31-2007, 01:12 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
No change in tension just by dropping the action slightly. There will be a slight change in intonation so that will need to be touched up slightly. Different string guage will affect tension for sure. Different brand strings of the same guage would probably not affect it. Check for shims under the locking nut as you may be able to remove them and get lower action in the first position. I like to fret the string at the 3rd fret and see the slightest space between the string and the first fret. Any more than a few slips of paper is higher than needed. I agree with GAZ on his comments but I prefer to go low action and switch to 10-46 for improved tone. Just my opinion.
fender strat, fender stratocaster, floyd rose, floyd rose guitar, locking nut, string guage, string tension
Jem7PBK - Question about the neck Martijn JEM and Universe Guitars 3 01-03-2007 09:04 AM
Quick question on 2x12s tobe Gear and Equipment 4 03-18-2005 08:21 PM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 03:41 PM
Bad horsie 2 question and Amp Question snorkthesick Gear and Equipment 1 04-11-2004 05:56 PM
WARNING: Stupid Floyd Question Ahead! Ugoyin Tech: Setup, Repairs and Mods 8 01-07-2004 08:56 PM
