Old 08-14-2007, 06:16 PM
kirk  is offline
Posts: 1,554  -  iTrader: (5)
RG2610 Trem Trouble
I know this has been addressed before, so sorry if I am beating a dead horse. I have a 2610 that constantly will not return to pitch after using the bar. It doesn't always happen, but when it does, I am usually mid song and have to slap or pull the bar to get the guitar back in tune.
I am pretty sure I have it setup properly - trem angle etc.
Any advice?
Old 08-14-2007, 06:54 PM
ShredderJoshW  is offline
Posts: 363  -  iTrader: (24)
Re: RG2610 Trem Trouble
You can check your trem angle on Rich's tech section on his website, but I woul also recommend "Nut Sauce" or any other kind of lubricate for nuts and saddles, or just use pencil shavings.
Old 08-14-2007, 07:03 PM
spider murphy  is offline
Posts: 100  -  iTrader: (1)
if your trem is set to the right angle, and your springs are not worn out check to see that every screw on the nut is secured firmly(snug not cranked down). first check the nut pressure pads, if they are loose then thats the problem. if your pads aren't loose, check the nut itself. it could be caused by a number of things tho. weakest link kind of thing.i would like to add that alot of trems i've had experience with have trouble returning to proper pitch after up pulls, but that may just be happening to me.
Old 08-14-2007, 07:09 PM
kirk  is offline
I know it is not the nut, nor anything above the neck. It has got to be something in the knife edges or springs. The springs shouldn't be worn out - it is pretty much a new guitar.
Old 08-14-2007, 07:12 PM
loose string saddles? it could be your knife edges, but why would they be worn so quickly on a newer guitar? maybe they just need to be reshaped, or maybe it needs to be worn in some more(springs, and edges).
Old 08-14-2007, 07:43 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Kirk i think rich has been seeing fat knife edges again so yours may be culprit. It seems that touching your bar puts it back in place so i would imagine thats where your problem lies . Anyways if its not the fat knife edges, check out your post, try a set of *trusted* springs, etc.
Old 08-14-2007, 10:53 PM
kirk  is offline
I just did a thorough setup and changed the strings, yadda yadda yadda. After the strings stretch a bit I'll try to see if I can isolate the problem. Innovation is great, but I do miss the Edge/Lo Pro Edge.
Old 08-14-2007, 11:07 PM
I think alot of guitarist do. Another revamp of the newer design is in order i think. As i dont recall when the lopro original edge were stock designs that people were complaining about wanting changes
Old 08-15-2007, 05:07 AM
Ploki  is offline
Posts: 193  -  iTrader: (0)
i lubricate the edge/stud point a bit. you know, friction and stuff
pro edge, string saddle
Best Trem Posts LonePhantom Tech: Setup, Repairs and Mods 12 05-02-2008 11:52 AM
Trem height trouble... Esperanto JS (Satriani Model) Ibanez Guitars 2 12-03-2005 03:15 PM
Help with Trem Cavity Cover... Shredcows Tech: Setup, Repairs and Mods 6 04-20-2005 08:20 PM
New JEM7VSBL and old Lo Pro trem LOUTHEBLUEGURU JEM and Universe Guitars 26 03-23-2003 05:16 AM
Lo-Pro Edge Trem Level? - Does the trem need to be level wit Dean Southcombe Tech: Setup, Repairs and Mods 5 06-11-2001 10:09 PM
