Re: rg770dx reissue edge trem question
Since this is a reissue with the Original Edge, yes, the ball ends need to be cut off. New higher-end RGs, Jems, JSs, etc. come with the newer Edge Pro bridge which does allow you to leave the ball ends on and feed them into the bridge, but not the Original or Lo-Pro Edge.
I personally string up Edges the opposite way, with the ball end at the headstock, but I cut some length of the strings anyway, so there's still cutting involved.
