Old 04-23-2006, 02:43 PM
knotty  is offline
Posts: 31  -  iTrader: (0)
RGA 121 pickup replacement wiring.
ANybody know the wiring to relace the v's with a SD jazz neck and a JB bridge. Keeping the same 5 options as original?
Old 06-06-2006, 02:17 PM
knotty  is offline
Re: RGA 121 pickup replacement wiring.
any ideas guys?
Old 06-06-2006, 04:28 PM
mfergel  is offline
Posts: 662  -  iTrader: (22)
Have you taken out the stock ones? I've got an RGA121, but haven't swapped out the pickups yet. I would think the stock ones are a 4 wire configuration and that the colors are probably the same between the two, so you should be able to just do a simple swap. I could be wrong, but.....
Old 06-08-2006, 02:05 PM
horstausmforst  is offline
Posts: 663  -  iTrader: (1)
check your other thread!
Pickup wiring AARRGGHHH Pickups & wiring 4 08-15-2006 08:30 AM
Different JEM7 BSB pickup wiring??? Steinway Pickups & wiring 2 08-23-2005 08:13 PM
JS neck pickup replacement (spacing) chemicalmagical JS (Satriani Model) Ibanez Guitars 6 05-16-2004 05:01 PM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 10:35 AM
Pickup Issue.. - Problem with wiring? MrBungle Pickups & wiring 5 04-15-2002 10:03 PM
