Old 03-04-2006, 05:17 AM
Bezial  is offline
Posts: 540  -  iTrader: (0)
shaping and neck joint on j custom
just curious if anyone else has noticed that the j custom bodies are shaped a lot more at the neck joint? what i mean is the acess is easier than either my rg or my jem and it is visibly so, heres a pic .
Old 03-04-2006, 11:24 AM
TAorama  is offline
Posts: 1,762  -  iTrader: (8)
Re: shaping and neck joint on j custom
I noticed it, but can't explain it. You'd think it would be as simple as reprogramming the CNC machine on the production line to get the additional shaping on the other RG's. Maybe they figure the high-production models will be subjected to more abuse and want more meat at the joint.
Old 03-04-2006, 11:29 AM
Rich  is offline
The J Custom AANJ has never been a secret.
Old 03-12-2006, 04:20 PM
kooshball  is offline
Posts: 52  -  iTrader: (0)
wow do all the jcustom guitars come like that?
Old 03-12-2006, 05:24 PM
Elysian  is offline
Posts: 324  -  iTrader: (0)
damn why doesn't my uv777bk have that?
Old 03-12-2006, 06:29 PM
technomancer  is offline
Posts: 663  -  iTrader: (6)
Maybe because it's an exclusive J-Custom feature
Old 03-12-2006, 10:30 PM
Bezial  is offline
got to love those exclusive features
heres another question , why are all the rear cavity plates metal? anyone tell me why as i cant see a reason.
Old 03-12-2006, 10:34 PM
damo7v  is offline
Posts: 1,150  -  iTrader: (10)
have heard that it increases shielding of the electronics.
my rg3120 has metal - my rg1302 j-custom has plastic...
Old 03-13-2006, 09:51 AM
Elysian  is offline
its all we use here at luthiery school...
Old 03-13-2006, 07:34 PM
Bezial  is offline
thats good but why? is it better to shield?
Old 03-14-2006, 05:46 AM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
Plastic doesn't shield, you need conductive paint over it (or a special plastic with carbon or metal particles) Metal covers don't need conductive paint, but you will still have to paint the cavitiy. Plus the metal plates will be very heavy.
@Damo7v: are you sure the cover is metal, not just painted metal?
Most metal plates need paint against corrosion, this would then break up the conduction between the painted cavity and the cover, resulting in RF leakage. So it would require additional grounding wires from the body to the plate...worse case: your metal cover becomes an antenna, do'h!
A smart luthier will use whatever he wants for a cover (but not metal) and paint both...guaranteeing condution and therefore RF-shielding.
@Bezial: the electrics/-onics inside your guitar will pick up radio and other stuff if you don't have shieldling.
Exclusive luthiers use wooden covers (and pickguards)
Old 03-14-2006, 11:31 AM
Rich  is offline
The covers are anodized aluminum.......
Old 03-14-2006, 11:57 AM
eviltwin  is offline
Images: 6
Which ones?
Old 03-14-2006, 12:14 PM
brothersnowgone  is offline
Posts: 1,498  -  iTrader: (3)
Reviews: 7
Originally Posted by eviltwin
Which ones?
He means the metal cover plates are aluminum(if thats what you meant by which ones and aluminum is a ****ty conductor). Although I prefer wood covers (esp. ebony covers). Although I don't see how a cover can become an antenna unless it comes in contact with something metal under the cover.
Old 03-14-2006, 01:57 PM
damo7v  is offline
yep. but the covers on my j-custom are plastic.
cavity cover, custom guitar, custom guitars, direct mount pickups, mount pickups, neck joint, patrick eggle, production model
FS: Custom Ibanez with nice goodies (large images) -=GuitarGuy=- Classified Ads: Guitars and Gear 12 11-29-2005 04:55 PM
New custom project (non-Ibanez?) screamndemon69 Other 6-string Guitars (non-Ibanez brand) 25 09-06-2004 12:28 PM
Locking nut screw holes, drill them before or after shaping? SilverSurfer2 Tech: Setup, Repairs and Mods 1 03-17-2004 08:24 PM
I refinished my neck - Bare wood & reshaped Les Paul 7-strin revsharp777 Tech: Setup, Repairs and Mods 2 12-19-2001 04:40 PM
