Old 01-18-2008, 07:08 PM
1RAPID  is offline
Posts: 3  -  iTrader: (0)
Simple Sound Question
I have 2 J customs at the moment,8570 (DiMarzio) & 8320 (EMGs), obviously these guitars have totally different pickups. Most J customs i see have a combination of the 8570.
Air Norton/Blue Velvet/Tone Zone or Air Norton/Tone Zone.
Before i add to my collection i just wanted to ask, If most of these guitars are equipt with the same pickups, how much difference is there between the different models and year? and how much difference is there between the different woods used to make them?
Thanks
Old 01-18-2008, 10:57 PM
Dan_H  is offline
Posts: 55  -  iTrader: (0)
Re: Simple Sound Question
I'll try and sum things up by comparing them to what you already are familiar with - this is not exhaustive, just some of the major trends and variations listed.
Woods - the vast majority are mahogany/maple top like your RG8570 which give a warm tone. Your alder RG8320 is a rare exception to that rule. Also some of the early models had ash bodies e.g. RG1302 which give a bright tone with lots of attack and clarity (or less warmth and depth, depends on your point of view and preference) Some of the earlier models were made of 3-piece instead of single piece bodies. Also bear in mind every piece of wood sounds different, so it's luck of the draw what tone you'll get from each individual guitar. Occasionally rarer woods are used e.g Koa tops.
Years - generally higher specs added over time e.g. Jem-style input jack, rounded fret edges, J-custom AANJ instead of Prestige style AANJ neck joint, velvetouch neck finish, recessed vol & tone controls, more abalone on the neck vines. Trems have moved over time from Lo-Pro to Edge Pro to Edge Zero for 2008 - personal preference which you like best.
Necks - last year's e.g your RG8320 were the thinnest so far. Your RG8570 feels about the thickest I've played. The older JCs with the Ultra profile are fairly beefy compared with your RG8320 but not as beefy as your RG8570. Occasional neck-throughs released, but usually bolt-ons.
For a good run-down of the ranges available since 1996 take a look at http://jcustom.web.fc2.com/index.html, I find that a handy reference - just click on the model names on the left. Also http://www.jemsite.com/jcustom/index.htm has good details, especially on the early models.
I hope that helps. Good luck in building your collection. J-customs own :-)
aanj neck, aanj neck joint, air norton, edge zero, neck finish, neck joint, tone zone
another stupid sound card question guitarshredder7 Recording Studio 7 08-03-2005 08:18 AM
Quick, Simple Question Tsorovan Tech: Setup, Repairs and Mods 5 05-07-2004 07:48 AM
A simple question concerning the sound of RG3120 particlestorm J-Custom, USA Custom & Prestige Ibanez Guitars 6 04-11-2002 04:48 AM
Egnater question kakan Gear and Equipment 13 06-15-2001 02:30 AM
POD Q..??? - simple question folks. strat110 Gear and Equipment 3 12-30-2000 05:35 PM
