Old 03-31-2009, 10:50 AM
DsrkHorse  is offline
Posts: 48  -  iTrader: (0)
Squeaking trem bar on Edge Zero What's up???
Anyone else got this problem?
On my 8470, when I rotate the trem arm, it makes this horrific squeaking- crackling noise. It was ok in the beggining, it started about a week ago. BTW it has an edge zero bridge. Any ideas or tips would be greatly appreciated.
Old 03-31-2009, 06:15 PM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
Re: Squeaking trem bar on Edge Zero What's up???
yeah, the bar comes with some oil on it, just re-apply some and it goes away. happens to me too.
Old 03-31-2009, 08:33 PM
korvus  is offline
Posts: 73  -  iTrader: (0)
It only squeaks because your amp is not loud enough!
Just kidding, try some oil.. I don't know if vaseline would help, but it would get really slippery.
On other hand, doesn't this bar have washers?
Old 04-01-2009, 04:28 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
be careful to put the oil on the tip groove only.
Old 04-01-2009, 06:30 AM
great, thanks guys, i though i might have broken something...
what oil should I use? is WD40 ok?
Old 04-01-2009, 07:57 AM
mcmurray  is offline
Posts: 83  -  iTrader: (0)
WD40 isn't oil. Maybe use some grease on a toothpick like nuno has illustrated.
Old 04-02-2009, 07:31 PM
scotteggshell  is offline
Also check the orientation of the little plastic ring that is inside the tension adjuster cap. There is a ridge that has to line up with the slot in the sleeve.
edge zero, noisy trem, problem
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 01:22 AM
WTB: Trem Arm holder for Ibanez Edge trem Dale Classified Ads: Guitars and Gear 1 11-10-2007 11:17 AM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 04:18 PM
wood squeaking using the Lo-Pro Pesso Tech: Setup, Repairs and Mods 9 09-20-2004 05:44 AM
RG550 and Edge problems with the Edge trem, please advice LaXu Tech: Setup, Repairs and Mods 7 08-13-2002 05:38 PM
