Stock V7 and V8 replacement question
07-04-2008, 01:33 PM
Force2BRW
Posts: 32 - iTrader: (
hi, i guess this is kind of a two part question.
1) What is the main different between the V7 and V8 pickups? Can you put the V8 in the neck position? Should you?
2) The reason is, i plan on getting a more powerful bridge pickup, and am wondering if i can move the V8 up to the neck if it is better. Also, the two pups i am looking at are the
Dimarzio
Evolution and the Seymour
Duncan Invader
. Does anyone have a preference or know any key differences beween them?
Thanks
Any comments and advise would be appreciated
Force2BRW
Find all posts by Force2BRW
07-05-2008, 04:18 PM
rub_800
Posts: 93 - iTrader: (
Re: Stock V7 and V8 replacement question
The neck and
bridge pickups
are balanced and if you put a bridge PU in the neck probably will be too loud..
Be carefull, if you want to put a EVO on 1570 you will need to do some routing.
rub_800
Find all posts by rub_800
07-05-2008, 04:29 PM
Ibateur
Posts: 2,949 - iTrader: (
Lots of guys on this board have added Dimarzio pickups to their guitars without routing. I have done the same several times.
Ibateur
Find all posts by Ibateur
07-05-2008, 06:00 PM
Lefty Robb
Posts: 4,930 - iTrader: (
rub_800
LOL!!!
Lefty Robb
Find all posts by Lefty Robb
07-06-2008, 01:10 AM
rvai
Posts: 458 - iTrader: (
Ibateur
some guys have had the same problem, the evo is very tall and the pup route is not deep enough,
tone zone
for example is not as tall as the evo and should fit
rvai
Find all posts by rvai
07-06-2008, 03:31 AM
Lefty Robb
Funny I've seen plenty of 1570's with Evo's that never needed any modifications. Perhaps there was a bad run of CNC bodies.
Lefty Robb
07-06-2008, 11:11 AM
HeavyMetal4Ever
Posts: 1,172 - iTrader: (
I have a 1570 with a
Duncan
Invader in the bridge position. It fit no problems, and it's way taller than the EVO.
The Invader has a thick, crunchy tone with alot of bass and bottom mids. Alot of people find it too muddy for their tastes. It's one of the hottest passive pickups on the market, and wasn't made with clean tones in mind. Apparently James Hetfield used one on the Master Of Puppets album.
The EVO is nearly as hot, but alot sharper. It sounds way more focused, and has alot more emphasis on the upper mids and the treble, and although it still has a full, punchy bass, the Invader sounds alot bigger and fatter. When it comes to clean tones, it's no
vintage strat
pickup, but it's way more versatile than the Invader. Some people describe the EVO as being too sharp, but when it comes to cutting through the mix it can't be beat.
If you want a chunky death metal riffing style tone, go with the Invader, but if you want a tighter, cutting tone more suited for leads check out the EVO.
Before you make your mind up, please note that i've read more than a few reviews saying that neither pickup is suited for basswood. Personally, i'm happy with my 1570 with Invader, so each to their own.
Hope this helped.
Rock on!
HeavyMetal4Ever
Find all posts by HeavyMetal4Ever
07-06-2008, 01:03 PM
mike570
Posts: 2,222 - iTrader: (
Reviews: 18
I had an Evo in my 1570. It was a pain getting in because of the spacer pad and the way the wire was sitting. Once it was in it was fine. It was a bit too high-end for my tastes on that guitar so I switched it out with a Tone Zone.
mike570
Visit mike570's homepage!
Find all posts by mike570
07-06-2008, 05:13 PM
rub_800
It was strange to me too but it's true. Mine is a 2008 1570. Maybe only aplies to the newer models. I'm not the only one who had this problem
http://www.jemsite.com/forums/showth...light=evo+tall
rub_800
07-06-2008, 09:41 PM
jallen
Posts: 631 - iTrader: (
Lefty Robb
My 1570 would not take and Evo without routing. I know of others who were able to drop it right in, but I can tell you for a fact that some 1570s will need routing for and Evo.
jallen
Find all posts by jallen
07-07-2008, 09:06 PM
HeavyMetal4Ever
Lets work out when they changed the routing. Mine was a 2006 model (early 2006 if that makes a difference), and it takes an Invader. I've had an Evo2 in it in the past.
Was year were the ones that had a shallower rout?
Rock on!
09:07 PM
. Reason: made a mistake?
HeavyMetal4Ever
07-07-2008, 10:34 PM
guitarman13
Posts: 388 - iTrader: (
What about the EVO2? Is that just as tall as the EVO? I'm eventually going to replace the
stock
pups in my 1570 also, but I'd prefer not to do any routing.
guitarman13
Find all posts by guitarman13
07-08-2008, 12:05 AM
Force2BRW
jallen
How much does routing cost?...and where can i get it done?
Force2BRW
07-08-2008, 10:06 PM
Ibanez-Mag
Posts: 520 - iTrader: (
There really are no thing as neck or bridge pickups, there all just the pickups.
Meaning that there is noting different in one or the other that makes it a specific neck or bridge pickup. The reason to call them one or the other is that is to help people chose pups, that this model in the bridge goes well with that model in the neck or this model was designed to work well with that model.
For example, most people use Air Norton as a neck pickup together with a stronger bridge pickup. But Air Norton is a great bridge pickup too, combined with an Air Classic or something like that and it is a killer bridge pickup.
The only thing most people want is a stronger bridge pickup then neck, but not even that is a must (look at loads of old teles with a humbucker in the neck and a singlecoil in the bridge). I also want my pickups to match EQ wise, so the difference between positions isn’t too bog, or it just gets very hard to get a balanced sound from your amp.
But the V8 would work great in neck position (even if I would have left the V7 there, because I don’t want or need the extra output and fatter EQ there, it just gets muddy and lacks dynamics to me).
Good luck with you pickup hunt.
I would go for the EVO if I were you and EVO2 if I were me :-)
No, then I would go for a Breed.
/Magnus
Ibanez-Mag
Visit Ibanez-Mag's homepage!
Find all posts by Ibanez-Mag
bridge pickups
dimarzio
dimarzio evo
dimarzio pickup
duncan
duncan invader
seymour
stock
tone zone
vintage strat
replacement for ibanez lo trs?
do original floyd rose work as replacement of jackson jt580
edge pro stud replacement?
how many coats of tru oil gun stock
how much would a fretboard replacement cost
Whats a good cheap replacement neck for a stock mexi strat?
AlkyHauler
06:07 PM
Neck replacement question
Ziggy_Franklin
Gear and Equipment
07:18 PM
Neck replacement question.
JN777
Tech: Setup, Repairs and Mods
12:26 PM
Pickup replacement question - Has anyone tried this?
neuromancer
02:36 AM
replacement inlay question - for my 7vwh
Cory Bottone
12:08 AM
01:18 AM
