Old 05-02-2006, 01:25 AM
Steve Brand  is offline
Posts: 13  -  iTrader: (0)
Question
USRG Part Needed - Please Help!
Hey there all!!! I'm hoping that somebody out there might just happen to have one of the plates that the locking nut mounts to on a USRG30 (tension free) neck? It's approx 22mm x 10mm with 3 holes in it - one to mount it to the neck 'bar' and two to mount the locking nut to it. Before I go to the trouble of fabricating one, I figured that I'd ask!!!
Old 05-02-2006, 10:11 AM
jkahrs  is offline
Posts: 477  -  iTrader: (6)
Re: USRG Part Needed - Please Help!
Email Bunker guitars. They're probably you're best chance of getting one. --Jason
http://www.bunker-guitars.com/
Old 05-02-2006, 03:49 PM
Thanks for the suggestion...I guess that I should have mentioned already having tried that approach and have also been in touch with Jim Donahue & Dave Bunker to see if those guys had one. No luck so far.....
Old 05-02-2006, 11:12 PM
jkahrs  is offline
So Bunker didn't have one? That's strange. I would have guessed that piece would be common to all his tension free necks that use a lock nut. That's probably going to be a difficult piece to track down. --Jason
Old 05-04-2006, 12:56 AM
TAorama  is offline
Posts: 1,762  -  iTrader: (8)
Try Treker guitars. According to Dave Bunker, his son runs Treker and has taken over all the Ibanez tension free stuff. They can build you a complete factory-style neck if you want. www.trekerguitars.com
Old 05-09-2006, 05:12 PM
Hey! Looks like that is going to be the solution...many thanks for the tip!!!
jim donahue, lock nut, locking nut
USRG Series Tension Free™ Neck karmatronic J-Custom, USA Custom & Prestige Ibanez Guitars 3 08-25-2005 10:41 AM
Replacement part problems. SV300 Comments to Ibanez 1 08-25-2003 02:31 PM
HELP needed! What DiMarzios to stick in my Ibanez USRG30??? SliderJeff Pickups & wiring 3 05-09-2003 02:02 AM
USRG 30 5 way switch dgbaker33 Pickups & wiring 4 09-27-2002 08:11 AM
Help with broken Jem! - Broken trem part Funeral9 Tech: Setup, Repairs and Mods 3 02-24-2002 01:06 AM
