Old 07-20-2008, 11:21 PM
newbieguitarmaker  is offline
Posts: 4,030  -  iTrader: (5)
Images: 1
Volume Pot Seizing
Hey guys I have a 2007 Rg2570 and my volume pot has seized up, after I get a proper size flathead to get the damn thing off I'll see if there is anyway of saving the thing. If not should I just buy a pot from Rich or are there better pots that will sound better than the ibanez ones or would it be risky for my tone to chg model pot?
Old 07-21-2008, 11:09 AM
Images: 1
Re: Volume Pot Seizing
Any ideas on which volume pot to get guys?
Old 07-21-2008, 11:18 AM
Ayrton  is offline
Just grab a 500k CTS pot locally and swap it out.
Old 07-21-2008, 11:30 AM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
Mine seized up in my RG550 20th ann. and I used the CTS pot but had to widen the hole in my pickguard and I also needed extra washers underneath to keep the height correct. I wouldn't think your tone would be affected negatively by using a non-Ibanez pot, if anything I would think there would be improvements due to the higher quality of the CTS pots.
Old 07-21-2008, 11:37 AM
Images: 1
ok, I will probably take out the pot and compare it to the ones at my local shop to see if its pretty much the same size because if the hole has to be bigger on my guitar I'd have to cut wood but I definitly believe that a non-ibanez pot would probably sound better since they seem higher quality than ibanez's, at least recent pots.
Old 07-21-2008, 03:28 PM
just4kinks  is offline
Posts: 76  -  iTrader: (4)
Sometimes you can save an old pot by spraying it with some contact cleaner and working it around. It might be worth a try, before you replace it.
Which Volume Tank Gear and Equipment 5 12-07-2007 09:40 AM
Volume @ Home S-man Polls 27 08-01-2006 02:11 AM
Volume Pot johnnyd529 JEM and Universe Guitars 2 05-09-2006 07:07 PM
Volume Pedals trouble311 Gear and Equipment 1 03-03-2004 04:23 PM
Volume Pot Scott 74 Tech: Setup, Repairs and Mods 16 09-21-2001 06:54 PM
