Whats the difference between a classic 1987 Wizard neck and a Wizard Prestige neck?
08-15-2007, 03:29 PM
Duck_man
Posts: 5 - iTrader: (
I was considering buying a 20th Anniversary RG550 with the original 1987 Classic Neck (which is totally killer), but I started looking at technical specs off Ibanez's website and the 1987 specs are excactly the same as the
specs.
Is there any difference between them, and if so, what is it?
Duck_man
Find all posts by Duck_man
08-15-2007, 05:48 PM
Jaden
Posts: 2,464 - iTrader: (
Re: Whats the difference between a classic 1987 Wizard neck and a Wizard Prestige neck?
have you done any research on this before asking ?
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
08-15-2007, 06:02 PM
JeffWiredBeck24
Posts: 181 - iTrader: (
WIZARD
Neck Dimensions
Scale Length: 648mm/25.5"
Width At Nut: 43mm
Width At Last Fret: 56mm
Thickness At 1st Fret: 18mm
Thickness At 12th Fret: 20mm
Radius: 430
WIZARD II Neck Dimensions
Width At Nut: 43mm
Thickness At 1st Fret: 19mm
Thickness At 12th Fret: 21mm
Radius: 400
Just a quick copy and paste of the Ibanez site for neck dimensions, the original Wizard is a bit thinner, and it's really up to taste and opinion. Some people prefer the original Wizard, some the Wizard II. Go to a
guitar shop
and try them out both and decide on your own experience with them.
JeffWiredBeck24
Find all posts by JeffWiredBeck24
08-15-2007, 06:54 PM
Ayrton
Posts: 4,157 - iTrader: (
44
The Prestige Wizards are listed as this.
WIZARD Neck Dimensions
Width At Nut: 43mm
Radius: 430
Ayrton
Find all posts by Ayrton
08-16-2007, 05:55 AM
Duck_man
Yeah I did research. The dimensions are listed excactly the same. My question is if there's actually any difference between them at all.
Has anyone actually played an RG Prestige and one of the new RG550XX's?
Duck_man
08-16-2007, 06:06 AM
psychoshredder
Posts: 1,022 - iTrader: (
i bought an amp a week ago, i played the amp at the
music store
using my RGR580Dx with original wizard neck. after a while I changed the guitar and took the RG 2610E from the wall and play it thru the amp.
I'm not goint to talk about how it does sound, but i can feel switching from my RGR580 ( ori wizard) to RG 2610E ( new w prestige), the neck on the 2610E is fatter and rounder, even it's only 1 mm thicker than ori W.
psychoshredder
Find all posts by psychoshredder
08-16-2007, 07:24 AM
Ploki
Posts: 193 - iTrader: (
original wiz is 17mm 19mm, like the super wizard. from what can i tell the difference is what psycho shredder said, the new wizard is not flat at the back. i personally like that
although, what is now
wizard prestige
used to be refered to as "Classic wizard" (2001 RG3120 for example)
Ploki
Find all posts by Ploki
08-16-2007, 11:39 AM
spider murphy
Posts: 100 - iTrader: (
i'm not sure if it's all of them, but it is worth noting that the
prestige necks
i've seen have a volute added to the neck to strengthen the neck behind the nut, and some of them don't have the nut fastening screws that thread in from behind the nut, and are top mounted(adding strength).
spider murphy
Find all posts by spider murphy
08-16-2007, 05:44 PM
Ironjose
Posts: 1,057 - iTrader: (
well the new prestige necks have a wenge setting or setup dont know what is the deal with it but it does feel very different between the classic wizard and the wenge neck...
Ironjose
Find all posts by Ironjose
08-17-2007, 12:30 AM
Duck_man
Okay, thanks alot guys, especially psychoshredder. Thats exactly the kind of info I was looking for.
Duck_man
08-20-2007, 12:01 AM
psychoshredder
anytime man!
psychoshredder
guitar shop
music store
neck dimensions
prestige necks
prestige wizard
wizard prestige
wizard prestige neck
WHAT is the difference between js1000 and js1200
guitar rusty cooley whats maney
parker are they neck thru
wizard ii is a jem neck
whats is ibanez 2010 line up?
Jem555 Wizard neck?
Thared33
01:32 AM
wizard neck vs. J custom neck thickness
finstah
08:18 PM
Wizard Prestige Neck Confusion
zyx345
11:34 AM
RG2120XTB - Ultra not Wizard neck ?
6828
01:45 PM
Jem 7DBK neck confusion...
Spagbol
05:48 AM
11:26 AM
