Will this warp the neck? - Jemsite
post #1 of 10 (permalink) Old 01-05-2013, 02:42 PM Thread Starter
I have my guitar currently tuned a half step down and the rest of my band can't be bothered to tune down as well so I'm stuck with transposing everything but it sucks at songs were I could really use open strings.
Is it bad for the neck if I tune to standard for about 3 hours without adjusting the trus rod and then back to half step down when I get back home? And I'd be doing that twice a week.
I have a 1570 by the way. I know the change is not much.. but I better ask first :P Thanks!
1990eam is offline
post #2 of 10 (permalink) Old 01-05-2013, 03:55 PM
Re: Will this warp the neck?
no it wont' but if I were you I would get another guitar. have one tuned 1/2 step and one tune standard.
GUITARMAGEDDON is offline
post #3 of 10 (permalink) Old 01-05-2013, 08:48 PM
I think that , besides the pain in the a** it is to keep tuning, the only problems would be that you might have slightly higher action when you tune up if your neck is nicely adjusted for the half down tuning. Or, you may end up with a little more fret buzz when you detune if your guitar is set up to play best at standard.
lynchfan6 is offline
post #4 of 10 (permalink) Old 01-05-2013, 08:49 PM
You could use a capo or if that feels too weird or too difficult to move fingering patterns then Morpheus do a 'capo' pedal. You could try that. Good luck!
GoodVaibes is offline
post #5 of 10 (permalink) Old 01-05-2013, 09:36 PM
No you wont need to adjust the truss rod, you might have to but its not going to warp your neck lol
Stealthtastic is offline
post #6 of 10 (permalink) Old 01-06-2013, 07:07 PM Thread Starter
Well I thought that maybe the constant change would affect the neck since as little as it might be there'd be different tensions for rather large periods of time.
1990eam is offline
post #7 of 10 (permalink) Old 01-06-2013, 07:43 PM
metalhead52's Avatar
Just recently started playing down a whole step and down a whole step drop d. Had to go up to 10-46 strings and add another spring to the trem but the neck didn't need adjusted on either guitar. Should not have to keep adjusting the truss for a half step.
metalhead52 is offline
post #8 of 10 (permalink) Old 01-09-2013, 01:04 AM
Ayrton's Avatar
Tuning up or down a half should not need any neck adjustments, and will no ill effects on the guitar.
However, it is a PITA on a floating trem. Perfect excuse to pick up another guitar if you ask me.
Ayrton is offline
post #9 of 10 (permalink) Old 01-09-2013, 02:19 PM
If you need to tune up or down grab a WhammyDT and use that instead to save you time and aggrevation. It works perfectly!
PBGas is offline
post #10 of 10 (permalink) Old 01-09-2013, 07:13 PM
Bingo, that's it and it doesn't sound as flaky as buying extra guitars to fully fit wardrobe or pumped up kicks.
63Blazer is offline
alternate tuning , neck , trus rod
Human Verification
Neck warp Jaxson_ Tech: Setup, Repairs and Mods 4 04-21-2010 12:57 PM
String gauge & neck warp Q's... Dudley Tech: Setup, Repairs and Mods 2 02-21-2008 11:12 AM
neck warp? cjk3910 Other Ibanez Guitars (including Premiums) 3 05-17-2004 08:13 PM
Hughes & Kettner WARP 7 Halfstack the.godfather Gear and Equipment 4 07-19-2003 03:14 PM
Neck warp... - ...looks like it's slightly, but don't know.. 7 Dying Trees Tech: Setup, Repairs and Mods 6 09-04-2001 06:01 AM
