Old 04-03-2009, 08:15 AM
Armann  is offline
Posts: 408  -  iTrader: (1)
Question
Wizard necks too thin ?
I was reading on another forum, doesn't matter wich one that Ibanez wizard necks are too thin and are more likely then other necks to bend and warp ?
Since I have only had one Ibanez guitar I can't comment on it since it was fine I was just wondering if this is something real and if you guys have had more trouble with your Wizard necks then other necks ?
Thanks.
Old 04-03-2009, 08:56 AM
vy100  is offline
Posts: 410  -  iTrader: (2)
Reviews: 3
Re: Wizard necks too thin ?
Donīt woory about that. Wizard necks can last forever if well conserved.
Old 04-03-2009, 10:01 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
being way more thinner than many other guitars baseball bats, of course they are more LIKELY to suffer from humidity and whatever, it's physics, but they simply won't actually do. even less the Prestige necks, which are 3-piece or 5-piece sandwich-built with titanium reinforcement bars inside.
Old 04-03-2009, 10:22 AM
Armann  is offline
Thanks for the answer guys, one of my students has a RG350DX and the neck is warped and then I read what some guys where saying on the other forum so I just started wondering, of course this can happen like it happened to me and my Strats when I moved from L.A back to Iceland
Old 04-03-2009, 10:38 AM
nuno  is offline
Originally Posted by iceland View Post
...when I moved from L.A back to Iceland
WOW! cool! cold! any pics of the wonderful land?
Old 04-03-2009, 03:23 PM
DsrkHorse  is offline
Posts: 48  -  iTrader: (0)
not sure about the korean models, but my '91 rg750 is in perfect shape, and after many trips back and forth from greece to canada. It's pretty cold there too....
Old 04-03-2009, 08:33 PM
AleTheNervo  is offline
Posts: 459  -  iTrader: (0)
i know we're speaking about wizards but even if it's a bit thicker, the original jem neck is quite similar...i got a '91 model and own it since 1996...never had to adjust the truss rod, and it's always in the perfect bend...don't know what to say...quite incredible, it seems to be made out of titanium itself!
Old 04-04-2009, 09:52 PM
PumpkinPie  is offline
Posts: 137  -  iTrader: (1)
I just bought a 20 year old RG550, the neck isn't warped...cracked, but not warped
Old 04-05-2009, 02:13 AM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
i think wizard necks do a good job at not warping. i think their main problem is the nut tension cracks. the thickness doesn't seem to be a problem.
Old 04-07-2009, 06:48 PM
adriandavidb  is offline
Posts: 118  -  iTrader: (0)
Where did you find this out from I havn't seen it in any marketing blurb? Very interested to find out more.....
Old 04-08-2009, 08:27 AM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
Titanium reinforcements:
http://www.ibanez.com/news/default.aspx?ceId=2526
Note that none of the improvements in Ibanez necks (regular cut-> quartersawn -> three piece -> multipiece -> titanium etc.) have ever come about because of customer complaints about warping.
They are the result of production optimization: Hoshino doesn't want to pay Fujigen for any production losses due to warping and Fujigen doesn't want to take the risk, building anything that could warp or fail otherwise during production.
Also note that Japanese Wizard necks have ALWAYS had a second reinforcement bar, between the regular trussrod and the fretboard.
http://www.ibanez.co.jp/anniversary/...t_id=198&now=9
Dunno about the Korean stuff...
Old 04-08-2009, 09:45 AM
Armann  is offline
Good info, so when they specially mention the titanium bar in the 3000 series that means what if all the wizard necks have them ?
"Super Wizard neck features the legendary ultra-thin, ultra-flat Wizard 17mm neck dimensions, but with 5pc construction and Titanium reinforcement bars for even greater strength (RG3000 models)"
Old 04-08-2009, 10:28 AM
kotornut  is offline
Posts: 1,847  -  iTrader: (0)
My '91 RG's neck is still in great shape.
Old 04-08-2009, 01:01 PM
Would my RGA321F have titanium reinforcement bars, or is it only the really expensive stuff?
Old 04-08-2009, 01:10 PM
Another question, the neck of mine seems to be constructed of three bits of maple, with really thin strips of (walnut?) dark wood between, is this a 3 piece neck or does the really thin stuff in between count, making it a 5 piece??
Also what's a 'wizard' or 'wizard2'? What's the difference between them? Does the RGA321 have either, or something else? The UK marketing info is a bit light on detail!
wizard neck
About necks! (Super-wizard, Wizard II and Jem) Ad_Astra Other Ibanez Guitars (including Premiums) 2 09-01-2008 06:37 PM
RG550 20th Wizard...too thin? Smitty J-Custom, USA Custom & Prestige Ibanez Guitars 45 10-12-2007 11:59 AM
PL650 & 540R thin,thin,thin sounding! zoner Pickups & wiring 3 06-04-2007 03:35 PM
RG 570 necks: Wizard or Wizard II leclaw Other Ibanez Guitars (including Premiums) 7 01-24-2006 07:32 AM
Getting used to thin wizard necks - fat necks vs thin necks, Guitarlos2 JEM and Universe Guitars 44 10-15-2001 06:15 PM
