Old 11-18-2005, 02:32 PM
stratoskier  is offline
Posts: 770  -  iTrader: (8)
Body wood for JS project
Greetings,
So it seems there are a few places out there that can produce a JS/Radius body. But there is a problem of sorts when it comes to picking body wood. I was originally thinking of a mahogany (or possibly alder) body with an exotic wood (birdseye, lacewood, ...) or figured maple top. But it has been pointed out to me that by the time you do all of the carving for the JS body contours, you'd have to have a really thick top to avoid ugly "shoulder" patterns (where the carver goes all the way through the top wood). Basically, it seems like the top would have to be as thick or thicker than the bottom. Given that fact, it was further suggested that I shouldn't waste my time with a separate exotic top, and should instead go with a full piece of exotic wood (whatever that turns out to be).
That brings me to wonder if a fancy top JS makes sense tonewise. We don't usually think of maple, for example, as being a superior tone wood when used by itself, so I wonder if a solid chunk of any of these woods would mean trading tone for fancy looks. I noticed that Gitarrero's beautiful JS custom guitar (pictures in a few old JemSite posts) does appear to be about 1/2 mahogany and 1/2 quilted maple. So at best, I could probably get away with 1/2 tone wood, and 1/2 pretty-to-look-at wood. Surely, by the time a top gets that thick, it's playing a major role in the guitar's resonance and tonality.
Anybody have thoughts about the wisdom of a full exotic wood body?
Cheers,
Bert
Old 11-18-2005, 03:14 PM
damo7v  is offline
Posts: 1,150  -  iTrader: (10)
Re: Body wood for JS project
i'd suggest staying with one complete wood for the js body style. the design just doesn't lend itself to having a separate top.
mind you, that doesn't rule out using wood that is tone-friendly and attractive. off the top of my head, i remember seeing seen curly/flame mahogany for sale on one of the wood dealer sites.
i think the biggest problem with using, say, a solid maple body will be weight. tone, well, there are so many variables that affect tone that i wouldn't rule out one type of wood solely for that reason.
Old 11-18-2005, 03:29 PM
I think you're probably right that a one-piece body make the most sense -- I'm starting to lean that way. I hadn't thought of figured mahogany: That's a good suggestion. From what I've read so far, other possibilites for exotic looking full bodies with decent tone properties would be lacewood, koa, or black limba.
Old 11-18-2005, 03:41 PM
tTz  is offline
Posts: 446  -  iTrader: (0)
I was convinced that I had read an article somewhere stating that when Les Paul researched woods for his original LP design, he found maple to be the best wood for tone, but was too heavy to be practical in a guitar, and so he settled for his second best, which was mahogany.
I must be going mad.
Ah, and I seem to remember the Parker Fly Supreme (I think, some sort of high end Fly) is made out of solid maple also. Can't be all that bad.
Old 11-18-2005, 04:45 PM
Interesting about the Les Paul comment -- hadn't heard that before. And yes, there are some solid maple guitars around. I also found an old thread here in which Frank Falbo and others noted that maple could be a very good tone wood, but the weight could be prohibitive in some designs. From the tonewood reviews I found on various sites, the consensus was that maple was typically bright, clear, and punchy. That description isn't what I would ideally go for, but it sounds like it might be an option in a JS, which is a pretty smallish guitar.
Old 11-18-2005, 05:04 PM
Devo  is offline
Posts: 1,482  -  iTrader: (20)
who will make a JS body.... please PM me or reply here if you think it isnt sensitive... would be very interested...
PS I would go for a solid figured bubinga, or koa.... like a Soloway swan....
Old 11-18-2005, 05:47 PM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Same here, I'm also interested in who can make a JS body.
Regards
André
Old 11-19-2005, 12:31 AM
King Knall  is offline
Posts: 2,445  -  iTrader: (0)
Solid maple as a body? I dunno, I've heard that it's too bright and heavy. I would go for Korina (Black Limba) and Koa.
Old 11-19-2005, 08:27 AM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
Hey, could we get a list posted here of JS body makers? I don't need one NOW, but such a list would be nice to have in "ye olde back pocket". I know that Creative Concepts guy, and probably EKG. Falbo, if you could lasso him into it
Old 11-19-2005, 08:45 AM
honky_tonk  is offline
Posts: 197  -  iTrader: (2)
there was a post the other day.with www. monsterguitarshop.com
i think that guy will make a js body too.....
also..... esp george lynch models...most of them are solid maple
Old 11-19-2005, 10:28 AM
buddroyce  is offline
I've actually had to restore an all maple Les Paul once(I think it was a 70's LP) complete with brass everything. Gotta say that it had some nice tone and weighed a hell of a lot more than your typical LP (even the old ones without the weight relief holes). But if I ever went and built another project guitar I'd probably go Swamp ash and maple. Both have great tone and the swamp ash will offset the weight of the maple.
Old 11-20-2005, 11:34 AM
Hey Guys,
Thanks for the responses...
Yes, Monster Guitars was one of the places that can do a JS body. The other place I'm talking to is a local luthier that has a duplicarver and can do one using my AANJ 540R as a template. I also think that either (or both) LGM and EKG have mentioned that they might get into doing JS bodies -- as forum sponsors, it'd be good to work with them. (Perhaps they, or other sponsors, will chime in here as far as their current capabilities for JS bodies).
Take care,
Bert
Old 11-20-2005, 01:26 PM
Jemmm  is offline
Posts: 426  -  iTrader: (0)
So you want JS body, hey?
How many do you want????
Any good luthier should be able to build you good JS/Radius type body. Specially with plans floating on the net. Duplicarver option is also a good suggestion. I've never seen JS shape from EKG or Jeremy. Those russian guys should be able to pull one off. (forgot their name, but know they did great JS-
** Edit: found it again. check www.shamray.ru
They did great JS-8 see: www.shamray.ru/show.php?id=419
Choice is very simple. Do you want great guitar on the wall or do you want great playing instrument. You can't have both. Yeah, you can.....but not on JS type contoured body. Most exotic quilted maple type drop tops you will see on RG type guitars......those tops mostly are not very thick...1/4"-1/2". This way the top will add to the looks of guitar and tonewise the maple will brighten the guitar up a bit. Quilted maple is very different animal then regular maple...and this is also something to think about.
A full koa body blank will set you back serious $$$$$$........so not a real option.
It's much easier to achieve what you are after with different kind of guitar.....JS is simply not very suited to do what your after. Again...the choice is between looks and sound.
The JS guitar shape is a wonderful guitar shape and wanting this type guitar in exotic trim is very understandable.......but an all maple guitar, or an all quilted maple guitar won't be a good player. Half/half will still not be great guitar.
If going for custom you're better off with picking the ultimate tone wood.....and having great solid (or custom painted) color on it. Then it will have THE looks and THE sound.
I have limba JS-7 in the works, and limba/quilted maple RGT-7 so yeah, I know what I'm talking about.
Old 11-20-2005, 01:42 PM
fettouhi  is offline
Haven't heard to much good about monsterguitarshop, that's why I didn't mention them.
Regards
André
Old 11-20-2005, 05:04 PM
Jemm, where is that picture from? Your shop? Or...? Incidentally, the JS body I'm after isn't standard specs, but will instead be AANJ with a 6-screw vintage trem, and possibly a middle single coil.
And thanks for your many insights! I appreciate the detailed post.
Bert
Maple as a body wood? (for a 7 string) hexa-db Tech: Setup, Repairs and Mods 8 01-22-2004 07:37 PM
Baritone body wood question failsafe306 Tech: Setup, Repairs and Mods 1 01-22-2004 12:43 AM
Guitar project custom body pickups configuration _FR0D0 Pickups & wiring 4 01-23-2003 01:47 PM
Broken wood on body...Fixable? - under the tremolo craig Tech: Setup, Repairs and Mods 1 02-06-2002 04:44 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Archived Topics and Common Questions - GO HERE FIRST 20 12-30-2001 01:44 PM
