Old 12-27-2005, 01:51 PM
Darran  is offline
Posts: 15  -  iTrader: (0)
Re: Changing strings
Originally Posted by Rich
Cut the balls off and do nothing but clamp down on the string.
If your saddles are loose, which is not uncommon on a new guitar, you can stretch all you want and the saddle moves and throws everything out of tune.
I took the guitar back the shop last week, and lo and behold you were right: the 'A' string saddle was loose. I was under the impression the saddles had been checked (in fact, I witnessed it!), but you can't argue with the facts I suppose, and it was loose.
BUT...
Although the guitar no longer has *severe* tuning problems, I still noticed that it would not remain in concert pitch for long. After 2 hours, I think I've diagnosed the problem, and its one I think Rich suspected earlier in the thread.
After depressing the bar, the G string flattens in pitch slightly; but I'm able to restore the correct tuning by pulling up on the bar. So, what's the problem?
Thanks
Old 12-27-2005, 02:07 PM
Rich  is offline
Most likely procedure. Read the whole page.
http://www.ibanezrules.com/tech/setup/lockdown.htm
Old 12-27-2005, 03:44 PM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
Also make sure the neck is tight to the body, and the screws that hold the nut on are tight (but don't overtighten). Anything loose will cause tuning problems.
Old 12-27-2005, 04:55 PM
Darran  is offline
It's specifically the G string that's affected by the trem, and I've followed your procedures meticulously, Rich. Having used a floyd rose for many years, I accept that there's no such thing as a perfect return, but I've never experienced anything like this.
Old 12-27-2005, 05:17 PM
Rich  is offline
It's not probable but it could be slipping through the nut.
Old 12-27-2005, 05:30 PM
Darran  is offline
Thought of that, but wouldn't the 'D' string be affected too? Turned the nut around anyway; no difference. Made sure the saddle's tight too; it is, and now it's rounded off (from too much tightening by the looks of it).
Old 12-27-2005, 05:41 PM
Rich  is offline
If only one string is affected, and you're following correct procedure, it's not slipping at the nut or saddle, and the string is fully stretched, i don't have any more answers for you.
[unless the string is coming back to pitch after a few seconds. G strings will flatten slightly when whammied and then return to pitch after a few seconds]
Old 12-27-2005, 07:13 PM
Darran  is offline
Unfortunately not, but thanks for your help; much appreciated.
Old 02-05-2006, 04:30 PM
Darran  is offline
Hello again!
During my time away from this thread, I've actually had my JS1000BTB replaced. The shop acknowledged that there was a problem with the trem (EDGE Pro) and thought the best resolution would be to offer a replacement, which I accepted.
However..
I'm experiencing a similar problem to last time. Specifically, if I raise the bar the strings go sharp, but if I immediately depress the bar the strings return to the correct pitch. Is this normal? And if so, how are you supposed to tolerate this in a live situation?
Thanks
Old 02-05-2006, 06:13 PM
DaveP  is offline
Posts: 37  -  iTrader: (1)
Check you trem and make sure is level with the top of the guitar. If the trem is not floating properly it will not return to 0.
Also I have found that cutting the ball ends off ensures that you will not have the wrap overhanging the saddle. This causes your string to sound dull and lifeless.
Just my 2 cents.
air guitar, edge pro trem, floyd rose, guitar tech, pro edge, string saddle
newbie here: changing strings drkillpatient21 Tech: Setup, Repairs and Mods 45 03-12-2003 04:34 AM
Changing strings on the EBMM JPM trem triaxis Other 6-string Guitars (non-Ibanez brand) 1 12-12-2002 01:06 AM
Question about changing the strings on my 1000 Scott 74 JS (Satriani Model) Ibanez Guitars 16 01-03-2002 11:05 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Archived Topics and Common Questions - GO HERE FIRST 20 12-30-2001 01:44 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Other 6-string Guitars (non-Ibanez brand) 10 05-09-2001 02:20 AM
