Dirty Volume Pot
Discussion about JS (Joe Satriani Model) Ibanez Guitars
01-21-2005, 09:13 AM
Jackhammer
Posts: 88 - iTrader: (
Dirty Volume Pot
A big round of applause for Algiman for helping me out with my previous problem (covered in my last thread).
There now seems to a noise that occurs when I adjust my volume (on my guitar). It sounds like a loose connection or something of the ilk (its not very loud , its a subtle sizzle).
How would I go about fixing that?
Jackhammer
Find all posts by Jackhammer
01-22-2005, 02:15 PM
Jackhammer
Re: Dirty Volume Pot
Pfft.....
I hate doing this but... *Bump*
Jackhammer
01-22-2005, 03:27 PM
Azrael
Posts: 403 - iTrader: (
Spray WD40 in it?
Azrael
Find all posts by Azrael
01-22-2005, 03:30 PM
Jackhammer
In the volume knob?!
Jackhammer
01-22-2005, 04:43 PM
Azrael
Yup.....works for most potentiometers if I'm correct.....
Azrael
01-22-2005, 08:22 PM
Algiman
Posts: 2,552 - iTrader: (
Azrael
Spray WD40 in it?
No no no no no! A can of contact cleaner will do the job. Couple of quid and you're sorted.
Algiman
Find all posts by Algiman
01-23-2005, 07:17 AM
Azrael
Algiman
Yeah , but WD40 is a fine contact cleaner.....
Azrael
01-23-2005, 08:38 AM
Algiman
It is also a lubricant, and is too thick for fine electronics like this. It will work, but electronic contact cleaner would be better.
Algiman
01-23-2005, 08:44 AM
Azrael
Algiman
Alright thanks for sharing. Will still work fine for my input jack though
Azrael
01-30-2005, 11:35 PM
Mo Fo
Posts: 30 - iTrader: (
Azrael
...and i hear it keeps the strings and hardware like new!
you can fix anything in the world with duct tape and wd40:
If it moves but it shouldn't - use duct tape.
If it doesn't move but it should - use WD40
Mo Fo
Visit Mo Fo's homepage!
Find all posts by Mo Fo
02-04-2005, 01:31 PM
The Doctor
Posts: 2 - iTrader: (
I had a similar problem with my js1000btb - including the tone pot. I had both volume and tone pots changed under warranty, but this didn't solve the problem. Turns out that it's a static issue - when touching the strings, there's no crackle when pots tweaked. If not touching the strings, there's a crackle. No way round it I was told, but it's not a big problem (at least for me).
The Doctor
Find all posts by The Doctor
02-04-2005, 02:55 PM
Azrael
Mo Fo
Paul Gilbert
uses it.....
Azrael
02-04-2005, 03:33 PM
whatshisname
Posts: 882 - iTrader: (
The problem with WD-40 is that dirt sticks to it. This is why you have to wipe the excess off, when you spray it on anything. If you don't, the problem will only come back worse than before.
But, if Paul Gilbert uses it, then I guess he would know more than I would.
whatshisname
Find all posts by whatshisname
02-08-2005, 05:06 PM
jem7vwh93
Posts: 40 - iTrader: (
Paul Gilbert also plays drums. Use radio shack tuner cleaner.
jem7vwh93
Find all posts by jem7vwh93
02-09-2005, 08:33 AM
Azrael
jem7vwh93
What's wrong with drums? Drums are awesome!
Azrael
paul gilbert
how to clean dirty neck
volume pot is stuck
how-to clean volume knob
emg 81 what volume pots
How to clean a dirty fretboard
HELP! Volume pot problem on my js1000btb.
Vaislittlefinger
09:26 PM
777DY wiring question(parallel/series) +volume question
mko
Pickups & wiring
08:06 AM
Volume Pedals
trouble311
Gear and Equipment
04:23 PM
Volume pedal for Solo boost
Dan D Mahnn
Gear and Equipment
02:03 PM
Volume Pots - 250k versus 500
Juniper570
Gear and Equipment
10:23 AM
11:19 PM
