Old 07-12-2008, 02:44 AM
AmazinAzian12  is offline
Posts: 549  -  iTrader: (0)
Dropping in Edge in a JS routed for a LO pro.
will it work? or will it need routing for the EDGE?
Old 07-12-2008, 03:02 AM
JayRobIBZ  is offline
Posts: 530  -  iTrader: (1)
Reviews: 3
Re: Dropping in Edge in a JS routed for a LO pro.
I am no expert, but if memory serves me right, they are more or less interchangeable. That is to say that the routs are not identical but are close enough that you shouldn't have any problems.
I'd get an expert opinion though. It has been several years since I have owned a floating trem guitar and a lot of the Ibanez specific knowledge I used to have has faded away.
Old 07-12-2008, 12:33 PM
CityofBlindingLights  is offline
Posts: 563  -  iTrader: (0)
Original Edge and Lo-Pro Edge are swappable without any routing required.
Old 07-12-2008, 07:44 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Usually, but not always. Not all Lo Pro routes have enough room at the back for the string lock screws on the Edge.
Old 07-14-2008, 02:43 PM
Red43j  is offline
Posts: 24  -  iTrader: (0)
Are the posts the same?
In my thread, some people were making it sound like there might be different spacing. Then again, I could have misunderstood...
Old 07-14-2008, 05:33 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
The posts are the same. The rout is similar because the tail of the lo-pro is actually longer than that of the edge's or they're equally just as long.
Jimmy
Old 07-14-2008, 08:55 PM
Red43j  is offline
So Jimmy-
Can someone actually upgrade from having a LO TRS II to the current Edge Trem (sorry, I forget the name, but you don't have to cut the ball end of the strings off? Thanks Jimmy-Red43j
Old 07-16-2008, 10:55 PM
jb4674  is offline
Reviews: 6
From a Lo TRS II to an Edge Pro, I don't think so unless you want to mess with the routing and the posts to make it fit. If, however, the JS has an Edge Pro II, the Edge Pro will more than likely drop in without any problems.
Jimmy
Old 07-30-2008, 04:16 AM
seppe_sai  is offline
Posts: 21  -  iTrader: (0)
the edge doesn't have a larger tail, thats an opticall illusion
Old 08-11-2008, 12:20 PM
jb4674  is offline
Reviews: 6
I didn't say edge, I said Lo-Pro.
Jimmy
string lock, trem guitar
The official Name Dropping thread. Darin Chat Forum 85 09-07-2009 05:15 PM
Thinking of dropping a floyd in... Matt08642 Other 6-string Guitars (non-Ibanez brand) 7 09-12-2007 10:40 PM
Dropping EMG's into JEM7VWH latinjem7vwh JEM and Universe Guitars 68 04-12-2006 08:04 AM
signal dropping on vwh dlp777 JEM and Universe Guitars 2 01-25-2006 04:31 PM
Rear routed/mounted? Front routed/mounted? Jeff Tech: Setup, Repairs and Mods 19 10-07-2002 06:36 PM
