Fret Buzz woes =(
Discussion about JS (Joe Satriani Model) Ibanez Guitars
06-18-2008, 05:37 PM
wandereruk05
Posts: 303 - iTrader: (
Fret Buzz woes =(
Hi all,
some of you may have read below - new JS1000 btb...
mentioned about a bit of a buzz problem which only seems to be getting worse. Only seems to be along the majority of the low E and the first 5-6 frets on the
wound strings
. playing a barre/power chord sounds horrible =/
i tried to raise the action a bit but nothing, tried to loosen the truss rod and it only got worse, put it back and it was the same, tightened it and it was the same, put it back and it was the same.
can anyone please help?
wandereruk05
Find all posts by wandereruk05
06-18-2008, 07:22 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: Fret Buzz woes =(
Is the neck shimmed?
Jimmy
jb4674
Find all posts by jb4674
06-18-2008, 07:25 PM
Rachmaninoff
Posts: 567 - iTrader: (
Reviews: 11
The 7th fret may be a little raised.
Check this out.
Rachmaninoff
Visit Rachmaninoff's homepage!
Find all posts by Rachmaninoff
axemanrio
Posts: 992 - iTrader: (
Yeah, as I mentioned in your JS1000 thread, add a
nut shim
... worked well for me, most of the fret buzz disappeared in the lower frets, strings 4-6.
axemanrio
Visit axemanrio's homepage!
Find all posts by axemanrio
06-18-2008, 07:32 PM
wandereruk05
jb4674
Jimmy
as far as I know its not - just from the shop, there looks to be a shim under the nut... if it carries on i'm gonna send it to a proper place for a setup... balls
wandereruk05
06-18-2008, 07:33 PM
wandereruk05
gonna have to try that out - what's the easiest way? take off all the strings and unscrew the nut from the neck?
as far as i know there is not a shim in the neck...just from the shop so i dunno - do they shim them from the factory?
wandereruk05
06-18-2008, 07:40 PM
axemanrio
My 2550 had a metal shim but it still needed a new .5mm shim to get rid of the major buzz. I did not remove strings to add the shim... just removed the 3
trem springs
and kept trem in place. That allowed me to move/lift the nut to add the new shim.
axemanrio
06-18-2008, 07:47 PM
wandereruk05
ah i see - will give that a go - will probably feel safer just loosening the strings tbh - dont wanna scuff up the body or cavity lol
wandereruk05
06-18-2008, 07:51 PM
GLG421
Posts: 323 - iTrader: (
Damn that sucks. I was waiting to hear about the great time you were having with the New JS.
Maybe when Rich finishes his UPS claim check sponsored European Vacation he can give you some insight into what he's seeing with the JS nuts these days. I seem to remember him stating that he was removing the nut and doing some grinding to level underneath the nut, so some nut shimming sounds like it might be necessary.
He packed a shim in my case, so I'm assuming he ground under my nut to level and used a different shim.
GLG421
Find all posts by GLG421
06-18-2008, 09:57 PM
Posts: 19,344 - iTrader: (
Latvia rocked.
Nut height
only affects the open strings. If loosening the truss rod made it worse I'm at a loss.
06-18-2008, 10:10 PM
CosmicDebris
Posts: 3,216 - iTrader: (
Rich, would a
warped neck
cause that?
CosmicDebris
Find all posts by CosmicDebris
06-18-2008, 10:17 PM
A bad neck could.
06-19-2008, 04:54 AM
wandereruk05
to be honest the neck looks fine - its not overly bent/bowed doesn't *look* twisted.
might send it for a setup somehwere - i dont mind a little bit of buzz - the nice twangy kind.
when you play a power chord and all you hear is buzz its horrible - it wasn't OVERLY bad before but noticeable. gonna string change and setup the bridge etc and see if that helps.
yay =(
wandereruk05
06-19-2008, 06:53 PM
P. Aaron
Posts: 257 - iTrader: (
After I received my JS1200 (right out of the box from the factory) I played it for a short while to:
1) Learn this "new" guitar.
2) Determine if "the factory setup" was worth a damn.
3) If I had a wish list; how would I tweak the new guitar.
I liked the feel well enough, but it did need refinement to my playing preferences, but there was no fret buzz, or extra issues besides just getting it tuned to my playing style.
If you have a local setup guy you trust, spend the few extra bucks on having it refined for you.
Make sure they know about
locking trems
though.
P. Aaron
Find all posts by P. Aaron
06-19-2008, 07:12 PM
wandereruk05
update time - added the shim under the nut. I just used some tinfoil and wrapped around one of the ones that were already there.
the action is quite high and the buzz is still predominant - letting the neck set from the truss moves and will lower the action and reset the neck tomorrow.
if that doesn't make much difference i'm sending away.
hate fret buzz.
wandereruk05
locking trems
neck relief
neck shim
nut height
nut shim
trem springs
warped neck
wound strings
how to fix fret board separation
how to get rid of string buzz
how to make a led fret
how to fret level
27 fret guitars?
Got a new guitar, but its got fret buzz on one string at one fret how to fix?
ibanezcollector
Tech: Setup, Repairs and Mods
07:43 PM
Fret Buzz on G n D 4th fret
EvanzRG
05:40 AM
Fret buzz on 14 fret (A + D strings)please help
Dave Goodland
02:30 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz
Superuser
05:35 AM
Strange fret buzz - Only at 16th fret, G string
carlos seo
12:12 AM
08:40 PM
