Help please¡¡¡¡ JS100
Discussion about JS (Joe Satriani Model) Ibanez Guitars
01-12-2007, 02:28 PM
ProgOn
Posts: 6 - iTrader: (
My JS100 just cant stayin tune, Ive done veerything from adjusting springs to changing the strings and it still gets out of tune, i gotta say im very dissapointed cause i thought the JS100 could be the guitar i was looking for but it isnt. Im looking for a guitar that stays in tune no matter how hard u use the bar. Any suggestions???? Maybe the JS1000????
ProgOn
Find all posts by ProgOn
01-12-2007, 03:08 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: Help please¡¡¡¡ JS100
Gotta ask the stupid question........
you mentioned you changed the strings but, did you stretch them properly?
Jimmy
jb4674
Find all posts by jb4674
01-12-2007, 03:18 PM
ApOsTle
Posts: 43 - iTrader: (
could be trem posts knackered, knive edges knackered, nut not shimed correctly, trem not set to neutral position , could be lots of things , check out 'Ibanez rules' tech section, or tech section of jemsite to make sure all is setup right first. i got a js100 and my main gripe is the trem ( mines LO TRS II ) so ive just got my hands on an edge LOPRO and gonna fit that soon. the LO TRS II is a terrible bridge for tuning issues although i cant say what the edge pro II is like on the newer js100's.
ApOsTle
Visit ApOsTle's homepage!
Find all posts by ApOsTle
01-12-2007, 03:30 PM
ProgOn
How do i stretch them (the strings) properly???
ProgOn
01-12-2007, 03:39 PM
jb4674
Reviews: 6
Yu have to bend the strings with the nut loosened. bend each string as hard as you can, or you can take the easy route and do a lot of pull ups with your whammy bar for each string.
Personally, I like bending the strings as opposed to using the bar (maybe I like pain).
Jimmy
jb4674
01-12-2007, 04:55 PM
RSVampire
Posts: 1,813 - iTrader: (
step 1) tune and stretch the strings properly:
http://www.jemsite.com/tech/restringing.htm
step 2) replace the TRS tremolo with an Original
Floyd Rose trem
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
01-12-2007, 05:15 PM
Jaden
Posts: 2,464 - iTrader: (
RSVampire
Floyd Rose
trem
ignore step 2: the TRS stays in tune just fine - check that you have streched the strings - that the trem is seated in the knife edges properly (ive seen them climb the studs) and check that your nut is tight.
after you have done all this you should be fine..
ignore the muppets flaming the TRS
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
01-12-2007, 05:45 PM
ApOsTle
whatisshredding
well, my trs II is naf
ApOsTle
01-12-2007, 05:55 PM
Jaden
why ?
and im not getting into the edge vs trs argument - cos there is no argument
does your trs stay in tune ?
I dont a setup on an rg470 a while back with a trs on it, i divebombed it for a ges and it stayed in tune - the guy picked it up from my house an dgave the bar some abuse - it stayed in tune !
whats the problem with yours ?
Jaden
01-12-2007, 06:03 PM
andy7jem
Posts: 6,504 - iTrader: (
Bear in mind the advice (here and ibanezrules) says leave the nut UNlocked overnight and re-tune next day BEFORE locking. Make sure you follow strictly to eliminate the obvious.
andy7jem
Find all posts by andy7jem
01-12-2007, 07:26 PM
jb4674
Reviews: 6
whatisshredding
+1 on that one. I've got a TRS trem on my yamaha and it holds tune just fine. The only bad thing is that the trem itself is very stiff but, it's not a bad guitar at all.
Jimmy
jb4674
01-12-2007, 09:36 PM
RSVampire
my step 2 was merely a suggestion to help the tuning instability. The TRS doesn't suck but does sometimes suffer from quality control issues.
Some
TRS trems
work wonderfully and stay in tune, while others can't stay in tune even with a nice pro-setup.
I suppose to avoid more flames on myself do these steps:
1) stretch strings properly
2) get the guitar a nice setup
how's that?
RSVampire
01-13-2007, 12:30 AM
ProgOn
Thank u guys¡¡¡ I followed Ibanez Rules instructions and now my axe is finally in tune. Gotta say it was fun to be adjusting the bridge, springs, etc. Now i can use the bar and go back to perfect pitch. Now im all set up and ready to rock. Tnx guys
Seize the Day
ProgOn
floyd rose
floyd rose trem
trs trems
how to tune a js100
whats the difference between a js100 and js 1000
do i get f spaced for js100
where is the js100 built
how to fit an edge on a js100
Autographed JS100 for sale/trade for 7 string
RG_76
12:17 AM
Js100 better than rg?
yummychopsuey
04:44 PM
Need some help with the value of a JS100
RG_76
05:49 PM
Please Help...Ibanez JS100 or PRS santana SE - Ibanez JS100
DouglasFyfeSco84
02:23 PM
Suggestions for my JS100
Scott 74
12:19 AM
03:47 AM
