Old 03-19-2002, 12:16 PM
david9  is offline
Posts: 4  -  iTrader: (0)
Ibanez JS1000 problems
Hi Everyone,
* *I wish my first post could be a more happy one but about a month ago i bought a Js1000btb brand new. Its a fantastic guitar but i can not keep it in tune. When i tune it i can maybe play for about 5 mins until every string slips flat by the same amount. This is augmented about 3 fold when i tighten or loosen the neck by the bolt at the top of the neck (truss rod i think). I have tightened the trem posts with the tiny allenkey and have even changed the position of the saddle lock back and forth to see if it made any difference but failed also. I like low action on a guitar but when i screw the tremposts down then loosen the neck to compensate it wont stay in tune for more than a few mins if that. Another thing i found to be odd was that when tuning i found that when i released the pressure from one string the other automatically tightened but a member from here advised me this was because of the floating bridge however it is making it impossible to tune and again this is augmented when the action is lower.My low pro edge baseplate is parrallel to the body and at the right angle.
After paying a lot of money for this i have hardly had a chance to play it man. Has anyone else had this problem or knows a way to solve it? *Any help would be most appreciated folks as its driving me mad!!
* * Thanks
* * * * * *David
Old 03-19-2002, 01:42 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
I'll assume this is your first floating bridge. Start at the top of the page and check every point on your way down.
www.ibanezrules.com/tech.htm
Old 03-25-2002, 09:46 AM
wireman24  is offline
Posts: 84  -  iTrader: (0)
Make sure your string tree is adjusted correctly if it is not your pitch can go sharp or flat when you lock the nut. Also another good thing to do and I can't stress this enough is lubricate every contact point on the bridge and nut and anything that moves. I use a graphite lube that has the consistancy of vasaline you can get it at any hardware store. Make sure you lube everything the saddles the bridge posts were the knife edge of the bridge comes in contact also lube the nut. I am a firm beleiver in doing this and my guitars hardly ever go out of tune. Also lube any contact point the string has with the guitar. You don't have to glob it on either just a nice amount trust me it works and it cuts down on the ware of your hardware.
Old 03-28-2002, 05:01 PM
david9  is offline
Thanks for both the replies folks. Ive finally got it set up and it plays like a dream that i can really begin to enjoy now. Thanks again
pro edge, string tree, truss rod
