Ive got uncontrollable GAS for a JS :)
Discussion about JS (Joe Satriani Model) Ibanez Guitars
02-02-2006, 07:18 AM
AirGuitar
JEM Winner #1
Posts: 821 - iTrader: (
I was thinking about getting a strat, but the more i think about the JS, the more i think ill be happy about having that coil tap
If i got a strat it would be a bit of a one trick pony, but having the humbuckers on the JS would mean id be able to use it for pretty much everything
At the moment, ive got a
EBMM JPM
, an RG1527, an RG570EX, and im half way through a RG to
JEM conversion
.... id just like to have a guitar without such a screaming tone, something a bit more controllable... and be able to get the single coil sounds (but im afraid if i bought a strat, i wouldnt use it for anything except playing blues every now and then).
AirGuitar
Find all posts by AirGuitar
02-02-2006, 07:41 AM
JESTER700
Posts: 2,234 - iTrader: (
Re: Ive got uncontrollable GAS for a JS :)
I don't think a JS is any more flexible than a strat - just different. You won't get true "strat" tones from a JS. Of course, you won't get JS tones from a strat, either. So, which do you want more? If you're not sure, you should go play them for a while. Or, get a JS and rout for a middle pup. Or get an HSH strat.... And what FEELS better to you?
JESTER700
Find all posts by JESTER700
02-02-2006, 07:45 AM
AirGuitar
JEM Winner #1
I wanted a good single coil bridge sound, a la Dave Gilmore. But if i bought a strat i dont feel id really use it enough, while id probably use a JS a lot more, as i generally like guitars with humbuckers on them.
The lack of a middle pickup isnt a problem, i prefer guitars without them, and i quite like the split coil sound of the 2 humbuckers in the middle position. I wouldnt go cutting up a JS for a middle pickup.
Did satch use his JS's to record all of his self titled album? Theres some very nice tones on there, exactally the sort of thing im looking for.
AirGuitar
02-02-2006, 07:46 AM
King Knall
Posts: 2,445 - iTrader: (
If you want a more 'flexible' Strat, I'd suggest the American Deluxe series. It's got those
Noiseless pickups
and the S-1 Switching system. Besides, a regular Strat is quite versatile. Just look at
Eric Johnson
. You can go a long way with the right setup.
King Knall
Find all posts by King Knall
02-02-2006, 08:34 AM
AirGuitar
JEM Winner #1
Kamikaze_1
If you want a more 'flexible' Strat, I'd suggest the American Deluxe series. It's got those Noiseless pickups and the S-1 Switching system. Besides, a regular Strat is quite versatile. Just look at Eric Johnson. You can go a long way with the right setup.
I was looking at a
deluxe strat
when i ended up going for the EBMM (was looking at a JS the same time too...).
Maybe ill take a stroll down to the
guitar shop
tomorrow lunchtime
AirGuitar
02-02-2006, 10:08 AM
JESTER700
MOST guitars are fairly versatile; there are few "one trick ponies" out there (esquires and EVH frankenstrats excluded)
But if you have a specific sound you need, some guitars "won't do that". EJ gets many tones, but "Eliminator ZZ Top" and "Megadeth" aren't among them. Of course, Pauls are versatile, but THEY don't do "early Dire Straits" or "Gilmour".
With the right HSH pickups you can cover a LOT of ground, but many will be somewhat of a compromise. This is why many people have lots o' guitars
If you have an EBMM, you might consider the strat simply because it's "more different". Of course, if you prefer H-H and get the sounds you need, the JS rocks. You pays your money and takes your choice...
...maybe just buy both.
JESTER700
02-02-2006, 11:38 PM
mike2558
Posts: 314 - iTrader: (
Get the JS1200
mike2558
Find all posts by mike2558
02-03-2006, 12:06 AM
carlos grijalva
Posts: 1,183 - iTrader: (
AirGuitar
coil tap
At the moment, ive got a EBMM JPM, an RG1527, an RG570EX, and im half way through a RG to JEM conversion.... id just like to have a guitar without such a screaming tone, something a bit more controllable... and be able to get the single coil sounds (but im afraid if i bought a strat, i wouldnt use it for anything except playing blues every now and then).
JS all the way!
carlos grijalva
Find all posts by carlos grijalva
02-03-2006, 12:11 AM
David McCarroll
Posts: 2,049 - iTrader: (
"If i got a strat it would be a bit of a one trick pony......"
Uh, I can't think of a more inaccurate statement than that......... if you want a JS, get one, but strats are probably the most versatile solid body guitar ever made.
David McCarroll
Find all posts by David McCarroll
02-03-2006, 03:08 AM
Sam b
Posts: 462 - iTrader: (
What do you guys mean by GAS????
Sam b
Find all posts by Sam b
02-03-2006, 05:04 AM
AirGuitar
JEM Winner #1
David McCarroll
I didnt mean the guitar itself is a one trick pony, but i myself would probably only use it for a few things when i really needed a single coil sound, id be unlikely to use it when i wanted a rock sound (as i tend to prefer the sound of distortion on humbuckers rather than a single coil) so would probably spend my time using my other guitars instead, making it not quite worth the purchase.
AirGuitar
02-03-2006, 05:06 AM
AirGuitar
JEM Winner #1
JESTER700
Thats deffinately a good point, i guess ill have to work out which would be best...
Getting both? Ill probably end up with one of each in a few years time, but at the moment, im trying to work out which is more important
AirGuitar
02-03-2006, 09:44 AM
saTa
Posts: 388 - iTrader: (
Get both. Honestly.
A
guitar collection
is incomplete without a strat and you do want a JS, trust me, you do.
saTa
Visit saTa's homepage!
Find all posts by saTa
02-04-2006, 04:16 PM
mike2558
mr vai
it's an acronym for Guitar Anxiety Syndrome.
mike2558
02-04-2006, 04:45 PM
JESTER700
MikeohollicA
...or "Gear Acquisition Syndrome"
...or "Getyer A-- outta Sight"... if SWMBO doesn't care for your spendy ways...
JESTER700
coil pickup
coil tap
david mccarroll
deluxe strat
ebmm jpm
eric johnson
guitar collection
guitar shop
jem conversion
noiseless pickups
uncontrollable gas
JS neck stats for custom neck - JS neck stats for custom nec
SilverSurferII
07:39 PM
js 7 string
cakewalkr7
11:41 AM
HELP!! js 1000 brand new bought..but then i held a jem!!
wideopen98
12:47 AM
Old JS 100BK
HDS
01:21 PM
Ed Roman Guitars and His view on JS guitars...
Lonely Raven
10:35 AM
05:20 AM
