JEM Neck on JS guitar?
Discussion about JS (Joe Satriani Model) Ibanez Guitars
06-05-2002, 02:41 PM
Lonely Raven
Posts: 491 - iTrader: (
I'm thinking about putting together a hybred guitar for recording in my
little home studio. I'd like to put a
JEM neck
on a JS body.
Has anyone done this? Is it a direct fit? Or would I have to do some
routing/drilling custome fitting?
Any help is greatly appreciated!
Lonely Raven
Visit Lonely Raven's homepage!
Find all posts by Lonely Raven
06-05-2002, 02:53 PM
EKG
Posts: 2,280 - iTrader: (
Well, a JEM neck is 24 frets vs the JS, which is 22, making the JEM neck longer. The neck pick-up would then be in the way for starters. You would have to remove it or reroute the pick-up cavity.
EKG
Visit EKG's homepage!
Find all posts by EKG
06-05-2002, 03:15 PM
BrianH
Posts: 599 - iTrader: (
I'm always amazed at what ideas people come up with, but I don't think this one is worth trying. Once you got it done, I don't think you'd be happy with the result.
BrianH
Find all posts by BrianH
06-05-2002, 03:34 PM
vaijem777
Posts: 2,980 - iTrader: (
I'm fairly sure that your intonation would be WAY off as well. 24-
fret necks
don't play well with bodies that were made for 22-fret necks.
vaijem777
Visit vaijem777's homepage!
Find all posts by vaijem777
06-05-2002, 03:38 PM
jemsite
Administrator
Posts: 9,271 - iTrader: (
both are 25.5 scale... so it is possible given patience and skill.
The only problem is what Eddie said. This is very similar to using an AANJ on a non-AANJ jem/rg, except worse, because the
neck pickup
will have to be moved. You also have to account for body depth at the heel joint, and profiling the neck if needed to leave enough wood in the pocket to attach the neck.
Not worth the effort IMHO... glen
jemsite
Find all posts by jemsite
06-05-2002, 03:43 PM
jono
Posts: 5,003 - iTrader: (
I think that it actually works perfectly. As Eddie and Glen both said, you need to either a) remove the neck pickup b) rerout the hole for it or even c) remove some of the overhang from the JEM's fretboard.
I've seen JEM necks on Strats (very similar to a JS) that fitted perfectly once the front pickup was removed. And even one on an old S540
The JS is of course routed for the old block
neck joint
so you'll have to use an old JEM neck unless you want to do a LOT of woodwork.
jono
Find all posts by jono
06-05-2002, 06:21 PM
Lonely Raven
I know the scale is the same on the two guitars, so the intonation won't
be to terribly bad. I just ordered a new
strobe tuner
. I'm hoping it's
going to show up before this weekend.
So I guess from the responses, that this hasn't been done yet.
Hmmm.
I'll have to see whats what when I get my next JS guitar. I'm going to be
taking it apart for a new paintjob anyhow...
Lonely Raven
06-06-2002, 12:51 AM
RSVampire
Posts: 1,813 - iTrader: (
you might acually be better off just paying/doing a vine inlay on your JS neck and removing the dots.
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
06-06-2002, 04:40 AM
Posts: 19,348 - iTrader: (
I'm surprised nobodies referenced the thread on the Chromeboy with the VBK neck. I'm on a dial up, somebody else go find it
06-06-2002, 12:15 PM
Lonely Raven
"you might acually be better off just paying/doing a vine inlay on your JS neck and removing the dots."
Ok, so I'd still have a JS neck. What if the whole purpose of this is to *have*
a JEM neck on a JS body guitar? Duh!
I've always loved Joe's tone, and the sexy curvy shape of the body,
and I'm a dual humbucker man, I don't even use the single coil on my
JEM or any of the strats I've owned. Honestly, I've usually had strats with
dual humbuckers in them too...
But I really like the JEM neck over the JS neck. It's just personal taste.
I'll see if I can find that post about the Chromeboy with the other neck
on it. Thanx for the tip!
Lonely Raven
06-06-2002, 12:19 PM
Lonely Raven
Can you maybe give me some more keywords to search? I can't seem
to find the thread your looking for.
I'm serious about doing this, as long as I don't have to trash a guitar to
make it work.
Hell, if I have to, I'll call that weido in Las Vegas and have him make me
a JS body routed for JEM neck. At least that way I can have it made out
of Mohogany rather then Basswood.
Lonely Raven
06-06-2002, 03:30 PM
rikkbeatty
Ibanez endorsed
Posts: 1,218 - iTrader: (
I was JUST about to post that
rikkbeatty
Visit rikkbeatty's homepage!
Find all posts by rikkbeatty
06-06-2002, 03:44 PM
EKG
Is this the
thread
? If so, I can't see the pic.
EKG
06-06-2002, 07:56 PM
rikkbeatty
Ibanez endorsed
Yup thats the thread. There was one other thread though before that one that had the pic on it before he ripped the pickgard off and left all the glue residue on the JS10. That poor guitar should be put out of its misery .....
rikkbeatty
06-06-2002, 10:31 PM
Lonely Raven
Well that was a very educational thread. Basically everyone complained
about butchering a Chromeboy.
So how does that help me?
Lonely Raven
fret neck
fret necks
jem neck
neck joint
neck pickup
neck pockets
strobe tuner
how do i fix a synsonics guitar?
how to fit led guitar neck
what age guitar
how to swirl a guitar
how do you put the strings closer to the neck on a ZR tremalo
02:47 AM
