JS Wiring Trouble, Please help me!
Discussion about JS (Joe Satriani Model) Ibanez Guitars
10-30-2008, 11:03 AM
moroneyk
Posts: 11 - iTrader: (
I am rewiring my Ibanez JS-100 guitar with a Dimarzio Fred in the bridge and a Paf Joe in the Neck.
I have wired as shown on the ibanez website (2004 JS-1000 wiring), but the is a VERY loud hum when plugged in and this increases when I touch the strings. I have double checked all the wiring, all solders are clean etc...
If you have any ideas on what might be causing the problem I would be very grateful, Is there maybe a fault on the wiring diagram? I have also tried the earlier wiring diagrams (1999 etc) but I have exactly the same problem?
If you have an alternative wiring diagram for a HH, 1 vol (push-pull high pass filter), 1 tone (push-pull coil split), could you please send it to me?
Thanks,
Kevin
moroneyk
Find all posts by moroneyk
10-30-2008, 11:08 AM
GuitarGuru
Posts: 763 - iTrader: (
Reviews: 3
Re: JS Wiring Trouble, Please help me!
Try checking the Input Jack. It sounds like a bad ground.
GuitarGuru
Visit GuitarGuru's homepage!
Find all posts by GuitarGuru
10-30-2008, 11:22 AM
moroneyk
Hi,
thanks for the fast response. That was what I initially though as well, I changed the input jack but I still had the same problem.
The pots are new, I have also tried changing them, all the capacitors used are new as well so no problems there (also tried changing them).
I've already spent 8 hours trying to solve the problem but with no luck, I'm sure it's some incredibly stupid mistake I've make but I just can't find it.
What is really bugging me is the fact that I tried the earlier JS 1000 diagram and I had exactly the same problem with that.
The pickups are new, Is it possible one of them is faulty? I've never heard of this happening...
Thanks for the help
Kevin
moroneyk
10-30-2008, 11:26 AM
S-man
Posts: 1,757 - iTrader: (
I doubt the pups are faulty. It does sound like a grounding problem.
Are all of the metal parts bonded together via a ground? This includes switch, pots, trem claw, etc.
S-man
Find all posts by S-man
10-30-2008, 11:30 AM
moroneyk
Everything is grounded except for the switch (not shown as grounded in the diagram). I have tried touching this to ground also but no joy
moroneyk
10-30-2008, 11:35 AM
S-man
If the switch has a metal casing it should be grounded.
There are usually three terminals on the output jack...did you you use the correct ones?
BTW...it's an output jack, not input.
S-man
10-30-2008, 11:38 AM
moroneyk
Actually I think I know what it might be. The metal part of the push pull pot to which I connected the pups ground may not be grounded. I need to check if its the same bit of metal to which the ground wire is attached. (pups ground attached at bottom of push pull, ground wire attached at the side).
I'll check that this evening and repost later. Thanks for all you help
I'll also ground the switch.
moroneyk
10-30-2008, 11:41 AM
S-man
You do have to ground the switch.
Here is the stock diagram....
S-man
10-30-2008, 11:45 AM
S-man
1 volume, 1 tone, H-H, 3way switch (bridge, bridge and neck, neck) w/push-pull for coil tap.
Push-pull for inner or outer coils.....
S-man
10-30-2008, 12:03 PM
GuitarGuru
Reviews: 3
S-man
Yes it is, but I've seen it referred to as both. Solder a wire to the outside of the switch to ground.
GuitarGuru
10-30-2008, 06:15 PM
moroneyk
Thanks very much, I got it sorted. It was in fact the output jack which was not wired to the correct terminal. I made the same mistake on the replacement jack as well, stupid stupid me...
Many many thanks!
moroneyk
10-30-2008, 06:50 PM
S-man
Cool!!! Make sure you have the polarity correct.
The ground usually goes to the tall terminal.
S-man
js wiring
stereo output guitar mono how to electric wiring
stereo 2x12 wiring?
wiring guitars - what wire to use
Ibanez Guitar wiring?
5 way switch how to wiring a ibanez
trouble with my C-7
HoP
Tech: Setup, Repairs and Mods
09:06 PM
JB/Jazz Wiring Trouble
Nickelo
Pickups & wiring
08:38 PM
JS1 ('90/'91) Volume Pot Wiring / Wiring Model?
guitarboy
05:31 AM
guitar cable wiring trouble
nocebo
Gear and Equipment
08:14 PM
Re-Wiring Question - Ha, semi-related to the "Wiring Questio
Two hands31
07:26 PM
11:44 PM
