Old 02-18-2007, 04:33 AM
j-o-d  is offline
Posts: 21  -  iTrader: (0)
js100 strap button HELP
everytime i play my js100 standing up, the strap pulls the screw on the top horn almost completely out of the guitar.... it doesnt unscrew it or anything, just pulls it straight out. i can push it back in, but it only pops out again if i put any pressure on it?? its yet to come COMPLETELY out the guitar, but it is close.
YES, its korean and MAYBE its not the best built js out there but how can i fix this? take it to a guitar shop or is it a DIY jobbie
Old 02-18-2007, 06:04 AM
alex10  is offline
Posts: 698  -  iTrader: (1)
Lightbulb
Re: js100 strap button HELP
just break some toothpicks into a couple pieces and put one of the pieces where the strap button screw would go then the strap button should stay put.
Old 02-18-2007, 06:13 PM
TommyGuitar  is offline
Posts: 206  -  iTrader: (0)
Cram as many toothpicks as you can in it mixed with wood glue. Let it dry, then redrill the hole the same size as the inner diameter of the screw and you're done.
Old 02-19-2007, 10:09 AM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
+1
Regards
André
Old 02-19-2007, 12:02 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
This is the solution.....
Go to a hardware store and purchase a small tube of Elmer's Wood filler
http://elmers.com/homerepair/product...asp?pCode=E855
Then:
remove the strap button
blow on the hole to remove as much particles as possible and clear out the hole for any particles of wood in there
apply the wood filler in the hole and fill it up the hole
as the filler is drying, try to compact it like a dentist does when he fills up a cavity in a tooth. Use a q tip to push the filler in when it is in the process of drying and apply some more to the hole to make sure it's completely filled up (wait about 20 minutes after you fill the hole to compact it).
let it sit for a day or so
screw in the strap button after it has sit for a day with a screwdriver and tighten it nicely but not too harsh.
let it sit for a day or two.
enjoy.
Jimmy
P.S.: the wood filler only costs about $2.00 here in the US, so it may be relatively inexpensive in New Zealand
guitar shop, strap button
proper place to install top strap button on a Seagull S6 Superuser Tech: Setup, Repairs and Mods 4 03-22-2010 01:37 PM
AR2000 Prestige -Upperhorn strap button belongs on heel/body jemsite Comments to Ibanez 9 08-26-2003 10:40 PM
moving a strap button... trajectory fish Tech: Setup, Repairs and Mods 5 07-06-2002 06:48 PM
How do I remove a stripped strap button screw? BrianH Gear and Equipment 8 06-30-2002 10:45 PM
Strap button problem....need your help! THE UNIVERSAL ONE Tech: Setup, Repairs and Mods 10 05-21-2002 01:32 AM
