Go Back   Jemsite > Guitars and Gear > JS (Satriani Model) Ibanez Guitars
Old 09-27-2009, 08:32 PM
chris101 chris101 is offline
Posts: 453  -  iTrader: (0)
JS1000/1200 string spacing
Hi,
Over the years I've had a few JS1000's and 1200's, but gradually sold them as I tended to prefer the slightly wider string spacing offered by RG and Jem necks. However now that I dont own a JS anymore (and sold my Jem) I'm interested to get a couple of measurements to compare against a few other guitars I own.
I'm interested in the overall width of the strings, when measured from low E to high E just after the nut and before the 1st fret.
So far I've measured the following guitars that I have to hand (ignoring my Universe!):
Ibanez Masa: Actual nut width = 42.50mm, string width after nut = 36.15mm
ESP M-II: Actual nut width = 41.44mm, string width after nut = 35.45mm
Fender delux american strat: Actual nut width = 42.00mm, string width after nut = 35.57mm
The reason I ask is becase of the 3 guitars, when playing between the 1st and 9th frets I am most fluid and precise on the electro-acoustic Masa, despite its high action, from 9th down its the ESP. Amazingly, that 0.7mm makes quite a difference.
If anyone out there has an accurate vernier/micrometer and could measure a JS for me I'm be most grateful, and the same measurement on an RG would be useful also! I suspect the JS might have a similar string spacing to the ESP.
Many thanks,
Chris
Old 09-28-2009, 02:46 PM
Silverburst's Avatar
Silverburst Silverburst is offline
Posts: 434  -  iTrader: (1)
Re: JS1000/1200 string spacing
Here ya go:
both equiped with 042-009's
JS1200ca (2007) : Actual nut width = 42.08mm, string width after nut = 36.15mm
RG8470 J custom (2007) Actual nut width = 43.03mm, string width after nut = 37.20mm
The RG makes me play a bit faster/preciser as well for now.
Old 09-28-2009, 04:49 PM
Thanks for the info. Out of interest I measured my Universe, just from low E to high E, thats a 'cramped' 35.5mm!
Old 09-29-2009, 10:29 PM
woodman300 woodman300 is offline
Posts: 9  -  iTrader: (0)
i measured my js-2000 and got slightly different measurements. 42.44 mm nut width and with 042-009 strings i got 36.44 string width at the nut. i have begun guitar building with a js replica that i made myself. the first neck i made started out with 42mm width at the nut but after shaping and sanding it got a little smaller. i too prefer a slightly wider neck so i guess i learned something from the first attempt.
Old 09-30-2009, 05:22 AM
It's the first time I've actually measuerd this difference in these guitars, and have to say I also have to work a little harder on the JS. But you universe 35.5 ?? that's really small, I can't remember that my UV777bk was that small, it felt like a big ruler
Old 09-30-2009, 03:21 PM
Yep, check it again and its 35.5mm, probably explains why I can’t do perfectly clean pull offs everytime from the 1st fret without clipping the adjacent strings on that guitar.
I'm suprised at how much wider the JS string spacing is compared to the ESP, maybe the radius on the JS mkaes it feel tighter to me than it really is.
Old 09-30-2009, 05:12 PM
Should be the opposite no ? the radius is a lot smaller on JS's, which would pull the strings a bit away from each other like they are on a cylinder. I've always prefered flatter radiuses myself, but I just can't step away from a JS being primarily a Satch fan when it comes to Ibanez signature models.
Ibanez Artcore AF105 Hollowbody Electric Guitar Natural
As low as $700
at 12 sellers
EVH Wolfgang Electric Guitar Vintage White Maple Top
As low as $3000
at 5 sellers
Members with more than 50 posts don't see this bar
Electro-Harmonix XO Octave Multiplexer Guitar Effects Pedal
As low as $74
at 3 sellers
Hal Leonard The Ultimate Elton John Collection Boxed Set
As low as $34
at 12 sellers
Breedlove Retro Series D/SM Dreadnought Acoustic-Electric Guitar Natural
As low as $549
at 6 sellers
Dean Razorback Cemetery Gates Electric Guitar Graphic
As low as $973
at 9 sellers
Hal Leonard Rock Band Guitar Method - Book/CD
As low as $7
at 12 sellers
Levy's Pierced Leather Guitar Strap Spikes
As low as $48
at 3 sellers
Cherry Lane Wolfmother Guitar Tab Songbook
As low as $12
at 9 sellers
Dean Exotica Quilt Ash Acoustic-Electric Guitar Transparent Braziliaburst
As low as $348
at 11 sellers
Taylor NS62-CE Nylon String Grand Concert Cutaway Acoustic-Electric Guitar Natur
As low as $2599
at 5 sellers
Eventide PitchFactor Harmonizer Guitar Multi Effects Pedal
As low as $440
at 7 sellers
Red Witch Deluxe Moon Phaser Pedal
As low as $298
at 5 sellers
Korg PitchBlack Pedal Tuner
As low as $10
at 90 sellers
string spacing
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
