JS1000 Breaks Strings
Discussion about JS (Joe Satriani Model) Ibanez Guitars
12-13-2003, 11:07 AM
phienix
Posts: 152 - iTrader: (
Hi guys,
i bought a brand new 03 JS1000BTB a month ago. it was setup perfectly and everything is ok its a sweet guitar, i love it. but till i write this every string from high to low e broke, and thats not normal, is it? what can i do to stop this? avery few days a string breaks and 5 minutes ago it was the low e string that broke.......
what can i do?
thanks
phienix
Visit phienix's homepage!
Find all posts by phienix
12-13-2003, 11:21 AM
EXCrosslink
Posts: 164 - iTrader: (
whoa a low E string broke? where did it break? at the contact point at the saddles or at the nut?
EXCrosslink
Visit EXCrosslink's homepage!
Find all posts by EXCrosslink
12-13-2003, 11:36 AM
saTa
Posts: 388 - iTrader: (
what strings do you use?
.009 gauge i reckon... but what brand?
saTa
Visit saTa's homepage!
Find all posts by saTa
12-13-2003, 12:18 PM
phienix
they all break at the intonation point at the bridge
i use 0.09 d'addarios
phienix
12-13-2003, 12:23 PM
saTa
you're referring to the saddles i reckon.
i suggest to loosen them, take them off and draw on there with a smooth pencil to make the saddles smoother and less hurting (damn... hard to say in english... check your icq, german :P)
saTa
12-13-2003, 08:44 PM
MehYam
Posts: 336 - iTrader: (
You're tuned to E, right?
MehYam
Find all posts by MehYam
12-14-2003, 07:06 AM
phienix
Sure!
phienix
12-14-2003, 08:35 PM
MehYam
And that's E below middle C, right?
MehYam
12-14-2003, 09:38 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Well are they breaking when you use the bar or what? I can break strings once a weak if i play alot, but my saddles are in no way sharp, just that if im playing alot im practicing with the whammy bar alot and when im practicing with it alot im breaking alot of strings *ill shut up now*
sniperfrommars1
Find all posts by sniperfrommars1
12-15-2003, 02:15 AM
phienix
It usualy happens when using the bar. If it would be one of the
higher strings
that break.......but the low d and e string? i'm waiting for the a-string to break ^^
phienix
12-15-2003, 05:46 PM
sniperfrommars1
phienix
It usualy happens when using the bar. If it would be one of the higher strings that break.......but the low d and e string? i'm waiting for the a-string to break ^^
Ive broken all the strings at one time or another its most directly attributed to wear. What kind of strings are you using?
sniperfrommars1
12-15-2003, 09:36 PM
rosster
Posts: 7 - iTrader: (
breaking strings
It may be that you havent tightened the retaining screws enough.
Thats happened to me before, if I don't tighten the screw, a few
strums later, BOINGG! the string just pops out. You can be sure if there
is no remnant of the string still sticking out of the vibrato block.
rosster
Find all posts by rosster
12-16-2003, 05:45 AM
phienix
Im using D'Addario 0.009 Strings.
And no, the String is really broke, its not popped out.
**** i dunno what to do now, ill call my dealer and ak him...
phienix
higher strings
WHAT is the difference between js1000 and js1200
what strings do you use for PRS
Liquid Trio Experiment When The Keyboard Breaks torrent
are ghs strings stiffer?
what kind of strings does korn use
07:59 AM
