JS1000 neck
Discussion about JS (Joe Satriani Model) Ibanez Guitars
10-25-2008, 04:56 PM
the
Posts: 31 - iTrader: (
JS1000 neck
Hey guys, so im loving my js1000. What i want is a hard tail strat body with the js neck, does anyone know a luthier that will make bodies for the js neck to bolt on? i contact warmoth and a handful of other kit manufacturer's already with no luck :<
the
Find all posts by the
10-25-2008, 05:08 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: JS1000 neck
If I'm not mistaken, a JS neck should be able to retrofit on a strat with no modifications required. The easiest way to be certain of it, is to take the neck plate off the js1000 and put it against the plate of the strat and see of the holes match.
Jimmy
jb4674
Find all posts by jb4674
10-26-2008, 07:32 PM
ryanb
Posts: 1,457 - iTrader: (
Re: JS1000 neck
Yes, you should be able to put a JS neck on a Strat. But why not just get a fixed-bridge JS?
ryanb
Find all posts by ryanb
10-26-2008, 07:43 PM
Factory5150
Posts: 116 - iTrader: (
Re: JS1000 neck
Maybe he wants 3 single coils...
Factory5150
Find all posts by Factory5150
10-28-2008, 09:53 PM
the
Re: JS1000 neck
really i want a different sound. The JS is fine live, but my strat HSH (sh-4 and sh6 humbcuckers, stock single coil) coil tapped gives me tons of sounds from great blues to super heavy, to great smooth jazz sounds. When i was doing studio work, it was the guitar that answered it all. The JS plays much better, but im relying more and more on effects and processing to get it done, so im hoping for a stratlike hardtail to let the wood talk a bit more. The JS is a unique sound altogether, but its just not there when it comes to versatility, anyone agree?
What i'm thinking now is pick up another JS, scrap the body, and get a warmoth body made outta some good tone wood and go from there.
the
10-29-2008, 08:14 PM
ryanb
Re: JS1000 neck
Hummm. I can't agree about a JS lacking versatility. But it is a subjective matter, and if the JS is not your thing, that's all good too. (Ain't nothing wrong with a Strat body for versatility either!) It sounds like you are suggesting it is the basswood body you don't like? Since you are talking Strat bodies, I assume you are looking for Alder or Ash. (You do know that most hardtail JSs are mahogany, not basswood, right?) What do you consider "good tone wood"?
Anyway, good luck putting together your new custom. As long as you end up with what makes you happy, that's all that counts.
ryanb
11-01-2008, 02:33 PM
the
Re: JS1000 neck
oh heavens, lots of woods are good tone woods to me. mahogony, alder, the hard ashes, even used to have poplar guitar that drove me nuts. Really what i think is lacking on the JS side of things is the bridge more than anything, it just doesn't let the wood talk to ya. As far as buying a hardtail JS, i dunno. It's crossed my mind more than a few times, buts it's hard to get that sound. when i picked up my strat, it was for one reason. it was one of the best sounding strat's (guitars) i;d ever heard. When i picked up the JS, it was for one reason as well. It was the one of the best playing guitars i ever picked up. In a live environment, you can make any guitar sound good, in any room, given a decent setup, and to me it's more about accurate playing. Give me the JS anyday for that, no question. In the studio though, to me its a little bit more about the sound, as you can always practice that piece and record again to get it accurate. To me, head to head, i think a strat just sounds a bit better overall than the JS. mainly because i look for that hard hitting SRV/KWS type sound. its hard to get it so thick wit the JS, i find myself swamped with pedals, whereas with my strat, i gotta chord into an amp. THis isn;t to say EVERY strat sounds better than every JS, just on the whole 100 strats to 100 JS's to my ear i'll chose strats. am i making any sense here? SO what i want is a strat, that gives me the left hand of the JS.
and a million jillion dollars.
the
11-03-2008, 03:32 PM
jb4674
Reviews: 6
Re: JS1000 neck
Have you tried using the coil tap at all? The JS1000 is able to recreate strat-like sounds when the coil tap function is engaged.
Jimmy
jb4674
11-04-2008, 02:18 AM
the
Re: JS1000 neck
yea i use it all the time, i actually replaced the hi pass filter on the guitar for phase reverse wiring, so i got phase reverse and coil splitting. This guitar is on its 5th set of pickups, and the neck pickup i have i like a lot right now for an all rounder, its the
Seymour PATB 1
and it really matches this guitar well. On my strat, i dont have a full on circuit for both picks humbuckers, each are individual wired, one toggle switch per pickup, so i could have 3 coils on if i;d like. tot of 9 pick up combinations. i wanted to do that to this JS, but with out the middle pick up it seemed worthless and hte phase reverse circuit was more handy. it also now has a
synth pickup mounted nice and tucked outta the way
on it now
the
WHAT is the difference between js1000 and js1200
parker are they neck thru
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Changing neck pickup in JS1000
Becksley
01:43 PM
JS1000 serial # and neck plate # difference?
magenta placenta
09:49 PM
JS1000 - Modelled on what neck?
Andrewkov
04:06 PM
JS1000 Digitized Neck First Year?
scarello
10:32 AM
WHAT IN THE WORLD???!!!...@.@ JS2000 neck on JS1000???
Mich
04:00 AM
07:05 PM
