js1000 whammy help!
Discussion about JS (Joe Satriani Model) Ibanez Guitars
12-30-2007, 08:31 AM
millzy
Posts: 170 - iTrader: (
js1000 whammy help!
ive got a js1000btb..the bar has always been like this and ive heard of some techniques to fix this but am not to sure..so id ask you guys..
my bar seems incredibly loose...whenever i let it go..it would full swing round..
i would like it to be exactly were i leave it..so if i finish using it...it would stay were i left it...but is still easy to move...
like the way
steve vai
's..any suggestions?
the trem is the old edge pro if anyone was inquiring
millzy
Find all posts by millzy
12-30-2007, 08:48 AM
jono
Posts: 5,003 - iTrader: (
Re: js1000 whammy help!
Edge Pro or Lo-
Pro edge
In truth I'm not sure if that makes any difference. Is it this collar that's loose or is it the bar inside the collar. My JS1000 has the Lo-Pro edge and the bar is fine in that so I'll talk about the Lo_pro trem for now.
There's a collar into which you push the bar that is tightened with a nut on the underside of the trem.
If it's the bar in the collar that's loose, you can get new white bushings for the
trem arm
that should stiffen it up a bit, or you can paint the end of the bar in nail varnish (aparently) to make it slightly thicker and thus have more friction against the spring.
Hope that helps
jono
Find all posts by jono
12-30-2007, 08:54 AM
richard1973
Posts: 957 - iTrader: (
Reviews: 10
i think someone on this forum mentioned before that they use tape (electricians or duck tape) wrapped round once to solve the problem.
richard1973
Visit richard1973's homepage!
Find all posts by richard1973
12-30-2007, 12:49 PM
millzy
thanks guys...
the trem is the edge pro...
its the actual trem inside the collar as you can hear it squeaking from drastic moves. good thing is ive got two new brushings so ill try everything
firstly ill try the electrical tape so thanks richard ill try it out...and get back
millzy
12-30-2007, 12:57 PM
JJEMMER777
Posts: 8,374 - iTrader: (
millzy
thanks guys...
Try the plumbers tape (thin) Wrap it once (or twice) in the slots and install the new bushings over it. Works like a charm
JJEMMER777
Find all posts by JJEMMER777
12-30-2007, 01:05 PM
twooos
Posts: 660 - iTrader: (
Or if you cant be assed doing that, take the bushings off the arm, paint a couple layers of varnish underneath where the bushings go, put the bushings back on, and there ya go
twooos
Find all posts by twooos
12-30-2007, 01:09 PM
JJEMMER777
And quick fixes aside, lets not forget this:
jono
You cannot tighten it without removing the trem. (which really is no biggie
JJEMMER777
12-30-2007, 02:14 PM
millzy
i tryed the electricans/plumbers tape..and it worked well..but its got that feel of ..'im gonna have to change it after a few days'.
once i placed a thin layer around the base of the arm it wouldnt fit in..so i placed on small 5mm strip over the brushings and that seems to have worked..but it was 5mm in breadth and about 1.5cm long..just placed over the brushings..
millzy
12-30-2007, 02:18 PM
JJEMMER777
millzy
Wrap it in the slots "under" the bushings. Don't wrap too much or the arm will not fit in
It really does work well! So do the other methods mentioned.
It's all about increasing ~girth~
JJEMMER777
12-30-2007, 02:25 PM
millzy
ahh i think that must be my problem..i simply wrapped the tape over it..
but the brushings must come off..and is it simply placing a layer on the 'brushing bit' and then putting the brushings on over the tape?
millzy
12-30-2007, 02:27 PM
JJEMMER777
Yeah, wrap a bit in the slots (directly on the bar) and then fit the bushings over it. It'll be a tight fit, but that is what you want
JJEMMER777
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
millzy
Precisely.
Jimmy
jb4674
Find all posts by jb4674
12-30-2007, 02:32 PM
millzy
ok..ill try this then..
in your opinions, when is the appropriate time to change brushings?
millzy
12-30-2007, 02:45 PM
JJEMMER777
millzy
Just change the tape peroidically as needed and you won't have to change the "brushings" as you call them, lol.
In other words, you can re-use the old bushings
JJEMMER777
12-30-2007, 04:13 PM
millzy
ahh right, here we go..
i tried these methods..the old electricians tape first, covering the brushing slots..it worked but i found the trem to still be slipping but not as drastically..
i tried a few more times but it was always the same so i just used the method that worked for me the first time..with a small strip places over the brushings
millzy
arm holder
pro edge
steve vai
trem arm
WHAT is the difference between js1000 and js1200
what is the proper diameter and thread pitch for ibanez s whammy bar
digitech whammy what do you use it for?
how to config the js1000 guitar
how to use whammy bar yamaha pacifica
WTT Black Edge whammy bar for a Black Lo TRS whammy bar
RG_76
07:03 PM
Changing Whammy settings
Freaker
Tech: Setup, Repairs and Mods
07:27 AM
jem 7v vs js1000
red5
12-07-2003
01:04 AM
js1000 or Jem 7v :)
red5
10:22 PM
1998 Black Pearl JS1000?!? Really a 1999?? Rich, perhaps?
Dominick Furlano
09:50 AM
04:40 AM
