JS1200 question
Discussion about JS (Joe Satriani Model) Ibanez Guitars
06-28-2006, 06:14 AM
Iceman24
Posts: 20 - iTrader: (
JS1200 question
Hey guys,
I just recieved my new JS1200CA! First off i would just like to say that it is the greatest guitar i have EVER played. Beiing an advanced player, i LOVE all the different sounds this guitar has to offer, and the TONE....OMG, like nothing else.
My question is, when i have the
coil tap
on, and the volume knob is raised, when i move the whammy bar over, i just sort of knicks it on its way around....Just like to know if anybody else has this problem.
thx
ALEX
Iceman24
Find all posts by Iceman24
06-28-2006, 11:24 AM
The Extremist
Posts: 110 - iTrader: (
Re: JS1200 question
i believe putting a shim in the neck pocket can fix the problem, but im not positive.
The Extremist
Find all posts by The Extremist
06-28-2006, 11:53 AM
cool_no9
Posts: 28 - iTrader: (
Re: JS1200 question
Hey Iceman,
Congrats for your new toy, great choice! Yes I do have that problem too with the whammy and the knobs way up.. I'm also trying to find a solution, perhaps playing around the trem holder in order to raise the
trem arm
but I'm not sure if that is doable.. in the meantime as the hi-pass filter is meant to brighten the tone at lower volumes, I just crank it up and forget about it..
Enjoy!
cool_no9
Find all posts by cool_no9
06-28-2006, 12:35 PM
mike2558
Posts: 314 - iTrader: (
Re: JS1200 question
congrats, I love my JS1200. I agree, the tone is just perfect.
not too sure about your question though. I usually play with all my knobs full.
mike2558
Find all posts by mike2558
06-28-2006, 09:15 PM
ryanb
Posts: 1,457 - iTrader: (
Re: JS1200 question
That can happen with low action and the trem sitting level. There's not a lot you can do. You could drop the trem angle a little bit. You could bend the arm. You could raise the action. You could put a shorter knob on. The
neck shim
would let the trem sit higher with the same action, so it would probably work, but i'd rather have the bar hit than use the shim. Not liking any of the options yet? But I agree. If playing at low volume with the knob up, how much are you really using the bar?
ryanb
Find all posts by ryanb
06-29-2006, 07:13 AM
RedShiftRider
Posts: 50 - iTrader: (
Re: JS1200 question
The knobs are not push on, they have a set screw, right? So for the volume knob, could you unscrew the set screw, take the knob off, pull the pot up, then screw the knob back in place with the pot permanently in the "up" position? Would that be acceptable? Is there any reason you'd not want the
high pass filter
engaged all the time? Then you could always lower the volume and not have to pull it out first. It doesn't solve the coil tap knob though. But I'm not sure whether it is hitting both knobs or just the volume knob.
RedShiftRider
Find all posts by RedShiftRider
06-29-2006, 07:57 AM
nuno
Posts: 4,725 - iTrader: (
Re: JS1200 question
the
arm holder
can be raised. just pull the springs out, flip the trem out of the cavity with the strings on, with a 10mm wrench unscrew the arm-holder nut you'll find underneath the baseplate, then unscrew the arm-holder itself from above with a large flat screwdriver (be very careful cause it tends to flip out and ding the bridge). now find the right height for the arm holder, then tight the nut firmly and set the trem back in place.
if you can't do that, have a pro doin it for you.
nuno
Visit nuno's homepage!
Find all posts by nuno
06-29-2006, 11:07 PM
Iceman24
Re: JS1200 question
Thx for all the reply guys, I use the arm ALOT btw. I love to play alot of Vai/Satch so i tend to use it alot. When i have the coil tap on and swing the arm over, it just grazes the top of the knob.
thx NUNO for the info, i will change the arm height first chance it get!
i usually slap on the coil tap with the
neck pickup
when im playing blues, turn the volume down a bit and it sounds AMAZING.
Guys, i cant believe how happy i am with this guitar, all day at work im thinking of playing it, then when i get home i cant put it down lol.
Iceman24
06-29-2006, 11:11 PM
Iceman24
Re: JS1200 question
double post
Iceman24
Iceman24
Re: JS1200 question
I have another question, I noticed something weird yesterday. When i bring the arm down to loosen the strings and it rebounds to original position, sometimes it doesnt return back to perfect tune, yet if i bring the arm back to tighten, it returns to perfect tune. Could this be a problem with the bridge. I intend to take it apart tommorrow in hopes of finding something out.
PS. I'm positive that the strings are 100% streched. thx for your replies
Iceman24
06-30-2006, 12:43 AM
Posts: 19,344 - iTrader: (
Re: JS1200 question
Improper technique
http://www.ibanezrules.com/tech/setup/lockdown.htm
06-30-2006, 01:36 AM
Iceman24
Re: JS1200 question
WOW thanks alot Rich!....funny thing, never had this problem with my OFR equipped Kramer.
anyhow, thx again!
Alex
Iceman24
arm holder
coil tap
high pass filter
neck pickup
neck shim
trem arm
How to maintain the JS1200
how to tune an ibanez js1200 properly
what styles can play with js1200
the action on my js1200 is to high
JS1200 or JEM77BRMR? not a poll, a personal question
Fabio
Gear and Equipment
03:14 PM
**** JS1200 scam.
CrazyD
09:02 AM
Question about ebay auction Question
Miata1476
03:41 PM
Bad horsie 2 question and Amp Question
snorkthesick
Gear and Equipment
05:56 PM
WARNING: Stupid Floyd Question Ahead!
Ugoyin
Tech: Setup, Repairs and Mods
08:56 PM
10:58 PM
