JS900 - Is the neck Multi Radius...................
Discussion about JS (Joe Satriani Model) Ibanez Guitars
08-23-2001, 01:25 AM
Scott 74
Posts: 1,293 - iTrader: (
This is just to let all the JS lovers(Rich) know that I checked the measurements for the JS1000 and JS900 on the Ibanez Japan website and they are exactly the same.
http://www.ibanez.co.jp/japan/frame_japan.html
Check it out on the Ibanez page!
So then the 900 must be multi radius?? right??? *LOL*
Scott 74
Find all posts by Scott 74
08-23-2001, 01:34 AM
Posts: 19,352 - iTrader: (
JS900
It would only mean anything if you could compare it to the 100 and the numbers were different.
08-23-2001, 03:42 AM
Scott 74
JS900
I don't understand! How can the measurements for the JS100 on the American site be the same as a JS900 and JS1000????
Scott 74
08-23-2001, 03:54 AM
JS900
You found the 100 specs??
08-23-2001, 07:09 AM
ripl3y
Posts: 747 - iTrader: (
JS900
Here ya go....
http://www.geocities.com/SunsetStrip...29/index1.html
Just move mouse over guitar neck and click on Tech.
Steve
(Edited by ripl3y at 6:12 am on Aug. 23, 2001)
ripl3y
Find all posts by ripl3y
08-23-2001, 12:52 PM
JS900
Thanks Steve, specs show exactly the same for the 100, 900, and 1000 (except the 250mm radius, I'm betting that's a typo)
parker are they neck thru
how to multi colour paint your guitar
JS neck fit a 540 radius?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
07:52 PM
