Old 08-27-2009, 02:22 PM
Toadfish  is offline
Posts: 227  -  iTrader: (3)
Just got a JS6! Need advice on cleaning it up / oiling
Hi guys,
after years of wishing I'd get one one day, I got a JS6 today.
It's in pretty good condition, but could do with a little TLC.
The body could do with a little cleanup (it looks like years of ground in body sweat - nice!) and it probably could do with some oiling. I[ve never had an oiled mahogany body guitar before so have no clue on maintenance. I've had a look around online and can't find anything specific on cleaning one of these up, so any advice would be welcome!
Can any of you give some advice on how to clean one of these babies up and get it looking a little more healthy?
Cheers,
Sukh
Old 08-27-2009, 02:25 PM
Agent540  is offline
Posts: 1,073  -  iTrader: (0)
Re: Just got a JS6! Need advice on cleaning it up / oiling
grrr don't trust to post a pic ! grrrrr
THISTHREADISWORTHLESSWITHOUTPICS !!!!!!
Old 08-27-2009, 02:37 PM
Toadfish  is offline
Easy big guy! Photo's later - just got home with it and posted this before I assault it!
Old 08-27-2009, 02:42 PM
Agent540  is offline
I'm not big !
and I should post : " I do not manage to post a pic / animated gif ! "
my patience !
Old 08-27-2009, 03:49 PM
vaijem777  is offline
Posts: 2,980  -  iTrader: (17)
Years ago, I had a "player" JS6 that had seen a LOT of use (sweat, gunk and other stuff, etc).
I basically took the guitar completely apart and sanded the body with #0000 Steel Wool.
Took some time, but it make the guitar look like new. I then applied a few coats of Tung oil, letting each coat dry and then buffing 'til smooth. Worked like a charm
Old 08-27-2009, 04:05 PM
Toadfish  is offline
Thanks! How did it look after the Tung Oil? Was the finish any darker / lighter than before?
Old 08-27-2009, 04:08 PM
It looked great after the Tung oil. Definitely lighter than when I got it, but mostly because all of the crud was removed. I only put on 3 coats of oil, so it wasn't terribly dark. No darker than a stock JS6
Old 08-27-2009, 05:12 PM
Toadfish  is offline
Thanks for the great tips buddy - really appreciate it.
Did you have to be particular when you sanded it (i.e. direction of grain or something), or just go wild with the wool?
I think I'm gonna try this.
Will post some 'before' pics tomorrow.
Thanks,
Sukh
Old 08-27-2009, 05:14 PM
Definitely proceed with CAUTION. Remember - sanding is still removing wood, even with really fine steel wool. It's much easier to remove wood than to replace it
Take your time and make sure you sand nice & evenly. Took me a few hours to really get mine done well, but it was certainly worth it
Old 08-27-2009, 05:57 PM
Toadfish  is offline
Thanks buddy.
I can see a project coming along. Might have to hold off for 3 months or so as I try to make my way across the pond again!
Cheers,
Sukh
Old 08-29-2009, 11:18 PM
frantick  is offline
Posts: 64  -  iTrader: (0)
Mine had a lot of wear from my strumming hand, took a couple hours total work to mask off pick-ups, steel wool, apply some tung oil, wipe, repeat. Got plain ol' tung oil from Home Depot. And I'm no wood-worker, THAT'S for sure.
Pics
Old 08-30-2009, 03:15 AM
Toadfish  is offline
That looks great!
Old 08-30-2009, 08:18 AM
Cam-Vai  is offline
Posts: 313  -  iTrader: (0)
Reviews: 4
probably one of the only hardtails id buy!
js6, satriani
oiling fretboard JasonMalmsteen Tech: Setup, Repairs and Mods 36 01-29-2007 11:42 PM
Oiling Neck on my VWH guitarman13 Tech: Setup, Repairs and Mods 37 01-15-2007 08:30 PM
Oiling a neck nienturi Tech: Setup, Repairs and Mods 4 12-10-2006 10:14 PM
Oiling a body? marianozz Tech: Setup, Repairs and Mods 11 07-10-2006 08:35 AM
Maple Fretboards - cleaning advice... rvj Tech: Setup, Repairs and Mods 22 06-27-2002 06:30 PM
