Old 07-17-2010, 07:12 AM
SP2333  is offline
Posts: 267  -  iTrader: (0)
My JS White Project...
Ive been Gassing for a white JS guitar for ages, and they dont come up in white often or the price is over the top, or i dont like baseball bat necks. So ive decided to create my own...Here is my progres so far..
- A JS100 body was bought from evilbay for a cheap amount. It makes me sick that im using a JS100 body but the fact is they are both Basswood and im gona strip it anyway and re route it for the edge trem makes me feel a little better... Call me fussy but a TRS trem route shape makes me nauseous
It took me 2 days to sand that crap translucent red finish off, then i re-routed the trem cavity to suit an original EDGE trem.
I also had to route the neck pocket to the correct depth. There was no way im going to have a high Korea stylr neck pocket depth. The foul korean trem studs have also been extracted tnd put in the bin. The correct locking type studs are being installed.
- I sourced a 1992 RG570 24 fret square heel neck from evilbay for a reasonable amount. I have test fitted it and chopped 2 frets off. I have also removed material from the last frets overhang so i can get it lower into the pocket for the correct fit. It is an "F" serial numbered 1 piece maple neck with the 17mm wizard 1 profile... My Preference..
- One of my main concerns was being able to source an original EDGE trem in chrome. As they are discontinued i thought it may be a bit tough to get.. I have sourced one from evilbay at a price you wont believe.. The complete trem,claw,springs,posts and stud inserts for a huge price of $95 dollars and i picked up also the chrome Toplok nut with bolts and retainer for a huge price $7... I was ovcer the moon...
- The stripped body has been dropped of to ETGUITARS for a complete re-finish in white. I was contemplating doing the job myself but i m going all the way with this job , so its off for a pro refinish with Ernie... Im hoping it turns out as good as his other work...
- Only the best is going into the build.. I have purchaced genuine Dimarzio Screw kits and will soon be getting the rest of the electrics. On the list is: Dimarzio push pull 500k volume and tone pots, Dimarzio Paf-Joe and Mo-Jo pickups....
- Im Still after a cast neck plate , so if anyone has one they want to part with please PM me...
Stripping JS100 Body of the spew finish... So thick..
Routing of body to suit EDGE Trem..
Stripped iand Primed body... Its now at ETGUITARS for the poly urithane white re-finish..
Old 07-17-2010, 07:14 AM
SP2333  is offline
Re: My JS White Project...
Test fit of RG570 wizard 1 neck...Note.. Wood under the overhang has been routed off for clearance in pic at the bottom.
Chopped..
Neck pocket depth routed down another 2mm..
Old 07-17-2010, 07:20 AM
SP2333  is offline
Final sanded body before delivery to ETGUITARS for the re-Finish...
Such an bargain , $95 for a late 80s Chrome EDGE.... Ill srip it and overhaul everything and polish it up when it arrives this week...
$7 is way cheap for this...
So this is what im looking at making... A White JS but with the neck profile that i like..
If the paint turns out as good as this ill be happy..
I will update this thread as things progress..
Alex..
Old 07-17-2010, 09:48 AM
Jeffplaysguitar  is offline
Posts: 51  -  iTrader: (1)
Wow man, that looks really nice. I would have kept the 24 fret neck, but whatever suits you
Do you think you saved any money doing this rather than just buying a white JS?
Old 07-17-2010, 10:06 AM
lerxst6  is offline
Posts: 339  -  iTrader: (13)
Awesome man. Definitely update the thread with pics when you get the body back!
Old 07-17-2010, 10:14 AM
SP2333  is offline
Dont worry ,My wife is keeping a tally of the costs......
Old 07-17-2010, 10:18 AM
lespauled  is offline
Posts: 239  -  iTrader: (1)
Reviews: 12
Wow, I was thinking of doing this to my S470. You may have just pushed me over the edge.
Old 07-17-2010, 12:17 PM
lerxst6  is offline
BTW, i've bought one of those from ibanezrules (rich) before. brand new, and i think it was equal or cheaper than you see used ones on evilbay.
Old 07-17-2010, 06:39 PM
SP2333  is offline
Unhappy
There is nil stock, and he has 9 on backorder for the last year.....
Old 07-19-2010, 05:50 AM
SP2333  is offline
Not a huge update.. But my Pickup screws arrived today...
Old 07-19-2010, 08:52 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
that's a very interesting pic, as it shows exactly where the 24th fret node is placed above the pickups, to get that Strat-ish snappy tone. nice!
wow, that must be one of the very early Edge trems, it has the rubber tubings on the retainer-bar mounting screws! congrats.
oh and great job, btw, the white JS rules
Old 07-19-2010, 03:09 PM
nato101010  is offline
Posts: 1,002  -  iTrader: (0)
That looks very very nice.
Ibanez/JS should take some hints here.
Old 07-20-2010, 06:39 PM
SP2333  is offline
BIG UPDATE...
Genuine Team J-Craft JS1000 neck plate just bought... Im happier with with this than a plain or crapped out one...wooooooooot negotiated a reasonable price too......
Old 07-22-2010, 06:04 AM
SP2333  is offline
Begining neck work tomorrow...Full fret level and ball ending plus polish...Ill post pics.
Old 07-23-2010, 10:34 PM
SP2333  is offline
First minor drama... The late 80s Top-Loc nut i got with the EDGE trem is a 42mm width and the chopped RG570 wizard 1 neck needs a 43mm width, So i had to order a new one to suit....
The Actual width of the 80s chrome nut is 41mm, and the black one on my 91 540R is 41mm. The cosmo nut on my 89 540S is also a 43mm.
So it looks like 43mm nuts are 43mm... And 42mm nuts are actual measurement 41mm. Wierd.
FS: *MINT* RG350DX body + DiMarzio strap (both white) - custom RG project! lewis.mann Classified Ads: Guitars and Gear 0 02-25-2009 11:31 AM
WTB Pickups: White X2N and White BREED NECK Yousef Classified Ads: Guitars and Gear 0 12-04-2008 01:04 AM
Ever wondered how much your project will cost ?? Post project costs here ! Jaden Multimedia: Music, Pictures & Sounds 12 08-29-2006 08:48 PM
RG7 strings in white - Where can I find A white RG7? SuperDweezil Other 7-string Guitars 6 03-23-2001 03:48 PM
Project Guitar Ideas - Opinions wanted on project jem7vwh Tech: Setup, Repairs and Mods 11 12-20-2000 12:27 AM
