Okay, so I didn't have the money for a 1000 and I found a cheap enough 100 on ebay. I figured if it had any major problems, that I'd save enough money to be able to fix them. No major problems except the tremolo. It seems that the tremolo never wants to return to it's original position. When I dive, it sticks just a little below in tune and when I pull it up, it sticks a little above in tune. I wish I would have known before how bad this tremolo is and my question is, can I get an
edge pro tremolo for this model js and if so where? I haven't been able to find any online without buying a whole nother guitar.
Also, I bought a dimarzio fred for the
bridge position and tried to wire it in. I'm not sure I did it right because the original pickup had 3 wires and the fred had 4. I tried soldering the 4 wires based off of dimarzios directions back to the same spot the previous wires were at, but that gave me a horrible tone. Especially when I pulled up on the tone knob. I downloaded the spec sheet for the js1000 wiring diagram since it uses a 4 wire pickup and it seemed to be wired into the tone knob on a different lead, so I tried that. The tone sounds somewhat better, but I thought that when you pulled the tone knob out, it was supposed to take it down to one coil. It seems it's just the opposite on mine. I get more body out of it when it's pulled up and more twangy when it's pushed in. So, can anyone give me some insight on fixing the pickup or fixing / replacing the tremolo? Thanks!
