Old 11-23-2006, 01:44 PM
Smitty  is offline
Posts: 841  -  iTrader: (1)
MY VOLUME POT EXPLODED!!!!!!!
Ok, so it didnt explode...I just needed to get everyones attention cuz this is really important. I was riding my bike, like, a block (why waste gas?) to a buddys to show his dad my new JS1000BP. On the way back, a shoe lace got caught in the wheel's spokes, and therefore I tripped on the bike fell over, dropped the gigbag...yeah. Luckily, it was a very nice Ibanez padded bag, so no dents or scratches. Not even a blemish of any sort. I checked it over, and continued the ride home. Well, when I got there, I said "lets play my beauitful JS..." and when I took it out of the gigbag, the volume knob, along with the shaft, came off. Ill try and get some pics to make this clear, but Ill just try and explain it. Instead of just the knob coming off, the knob and the shaft its connected to came out of the volume pot. So where the knob once was, there is just a hole and the knob itself has the shaft connected to it, so therefore I can put the shaft (and knob) back into the volume pots hole, and then I can turn the volume which way I want, but there is no push/pull option because...well....duh the shaft has to be connected to whatever inside the pot to be able to pull up on the knob. And also I dont like having my volume knob coming out if I move a certain direction. So...what should I do? Id absolutely hate to replace it, but when I opened up the rear electronics cavity, there was nothing to help me there. And I thought I might ask you guys what to do before I took the pot itself out. Again, sorry if this is sort of fuzzy to you, if you need it, Ill get some pics up. Thanks alot in advance for your help!!
smitty
Old 11-23-2006, 02:26 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Re: MY VOLUME POT EXPLODED!!!!!!!
What's the big deal?
Just replace the pot and get it over with.
Old 11-23-2006, 03:08 PM
dragsternj  is offline
Posts: 1,707  -  iTrader: (12)
yup, but thanks for the tale
Old 11-23-2006, 03:16 PM
Lefty Robb  is offline
never ride a bike while carrying a very expensive guitar especially one thats just in a gig bag, just walk...
Old 11-23-2006, 04:22 PM
Smitty  is offline
Nah but Id like to see if I could get it fixed first. But yeah if Im gonna replace that, where should I buy it at? And if I do that, Id like to have the high pass filter on all the time...so how would I go around doing that?
smitty
Old 11-23-2006, 04:24 PM
elcid  is offline
.....nevermind....
timi_h  is offline
Posts: 1,104  -  iTrader: (0)
volume pots cost nothing! a repair job would probably cost more than a replacement
Old 11-23-2006, 04:32 PM
Potentiometer: $10
Solder and Iron: $20
Knowing you came within an inch of snapping your guitar neck, but didn't: Priceless
Old 11-23-2006, 04:33 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
It can't be fixed. Shock knocks the clip off the end of the shaft that kepps it locked in the pot. If you want the high pass on full time you don't need the push pull, just a vol pot. Follow the JEM wiring diagram to wire it. You will need an asian pot to get the right diameter shaft [or your knob won't fit].
Old 11-23-2006, 06:03 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Let's see, you were riding your bike for a block with an Ibanez JS1000BP on your back and you fell? Well, you should've known better. A one block walk won't hurt you.
Call Ibanez and get a pot replacement along with the knob.
Old 11-23-2006, 06:33 PM
Smitty  is offline
Thanks. My bike needed some love. I was just asking if I could fix it myself, ass holes.
Old 11-23-2006, 07:15 PM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
You CAN fix it yourself, as Rich said, but the fix is to replace the pot, not try to repair the broken one - it'll just give you grief regardless of how you try to repair it - and besides, as he said, if you want the hi-pass on all the time, you don't need the push-pull pot, just walk into any large electronics hobby shop (Radio Shack? dunno who you've got in the US these days) and buy the appropriate value Linear Taper pot - as Rich said (he's a fountain of knowledge!), you have to get an Asian made pot as the shaft is very slightly smaller in diameter that US made pots - but I believe almost anything you buy from a major dealer these days will come from Asia anyway - take the remains of your pot and the knob to test for fit in any case.
Don't be too hard on your fellow Jemsiters - I think their concern is that you could have had a much worse accident than you did! We live and learn!
Cheers
David McCarroll
Sydney, Australia
Old 11-23-2006, 07:24 PM
wow, calling us all ass holes, hmmm what are you, 12? Must be comming from someone who puts a $1200 guitar on his back with no hard case while riding a bike to go 1 block and falls off...
Old 11-23-2006, 07:56 PM
vette6600  is offline
Posts: 881  -  iTrader: (0)
what do you guys expect? only 2 of the responses were helpful without being rude. i wouldnt call people ass holes, but i can definitely see his frustration.
anyways, best of luck getting that worked out
Old 11-23-2006, 08:56 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
If you do something stupid, and then post it in an internet forum for the world to see ... you are going to get some responses pointing out how stupid it was. Don't go getting pissy about it. If you didn't want criticism, don't post it! Besides, I didn't see any responses that were particularly rude -- at least not enough to evoke that response.
Now drop a few bucks, slap a new pot in there, and move on. No harm, no foul. Everybody has accidents, and this is a simple fix.
david mccarroll, high pass filter, volume pots, wiring diagram
Effects loop volume drop in Prosonic sanchez Gear and Equipment 3 05-31-2005 09:06 PM
HELP! Volume pot problem on my js1000btb. Vaislittlefinger JS (Satriani Model) Ibanez Guitars 5 03-03-2005 09:26 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 08:06 AM
Volume Pedals trouble311 Gear and Equipment 1 03-03-2004 04:23 PM
Volume pedal for Solo boost Dan D Mahnn Gear and Equipment 7 06-21-2003 02:03 PM
