Old 01-02-2008, 02:25 AM
eg  is offline
Posts: 259  -  iTrader: (0)
Neck/Bridge Volume differences on JS
Have you guys noticed any volume differences between the neck - pafpro and bridge - fred pickup on your JSes?
I've read that for equally powered pickup, the neck position would sound somewhat louder because the string amplitudes are greater there. Then given the fact that the pafpro and the fred are quite close in terms of output, then would this cause the paf pro to sound kind of louder that the fred.
I have the same pickup config on my RG and I notice there the neck pickup is slightly louder.
If this is true, how do you guys compensate?
Thanks
Old 01-02-2008, 03:01 AM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
Re: Neck/Bridge Volume differences on JS
the Fred is a little higher output than the Paf Pro which is perfect
if your neck pickup seems too loud try lowering it with the adjustment screws or try raising your bridge pickup.
Old 01-02-2008, 08:06 AM
millzy  is offline
Posts: 170  -  iTrader: (0)
i noticed itm but it was because my paf pro was higher than the fred..so i lowered it and its now below in its cavity whereas the fred just sits on the top
Old 01-02-2008, 11:00 PM
eg  is offline
Alright, I guess I'll have to adjust the heights to compensate
bridge pickup, neck pickup, neck position, paf pro
Effects loop volume drop in Prosonic sanchez Gear and Equipment 3 05-31-2005 09:06 PM
HELP! Volume pot problem on my js1000btb. Vaislittlefinger JS (Satriani Model) Ibanez Guitars 5 03-03-2005 09:26 PM
Volume pedal for Solo boost Dan D Mahnn Gear and Equipment 7 06-21-2003 02:03 PM
Old JS 100BK HDS JS (Satriani Model) Ibanez Guitars 2 12-31-2002 01:21 PM
JS PU change sugguestions? - im thinking about changing out SuperUnderwhereMan JS (Satriani Model) Ibanez Guitars 23 01-30-2002 09:15 PM
