Old 01-20-2013, 10:10 PM
AlienKarma  is offline
Posts: 68  -  iTrader: (0)
Question
Neck specs and Gotoh bridge 1996 JS 1000 TB
Hi!
I have 2 questions for the JS gurus.
First I want to know now the full neck specs of a 1996 JS 1000 TB (#3616)
Second I want to know if a Gotoh Floyd is compatible with this guitar. I want to change the lo-pro edge for a Gotoh one.
Thanks in advance,
AK
Old 01-20-2013, 10:16 PM
jb4674  is offline
Posts: 4,375  -  iTrader: (0)
Reviews: 18
Re: Neck specs and Gotoh bridge 1996 JS 1000 TB
Originally Posted by AlienKarma View Post
Hi!
Thanks in advance,
AK
Why would you want to replace the trem? Is it because of the profile? If that's the case, you can put an Edge in place of the Lo-Pro. It should retrofit without modifications and it will have the same look of the Gotoh.
Jimmy
Old 01-20-2013, 10:28 PM
First of all thanks for the reply.
The change is about quality, and stability. Regarding your reply, it will be necessary mods to put in a Gotoh one? I was hopping it could be a "plug and play" procedure.
I also need the neck specs because it needs a fret dressing.
Regards
Old 01-21-2013, 06:38 PM
After all it seems this JS 1000 TB is from 1994 (I bought her new in 1996). Unless I'm mistaken, this was the only year they were made with this finish transparent blue (TB).
Can anyone confirm this?
Regards,
AK
PS:Still looking for some answers regarding my original post.
Old 01-21-2013, 07:02 PM
satchmo72  is offline
Posts: 1,462  -  iTrader: (28)
I dont know the answer to your question but I can say this, the Edge trem is one of the most stable trems I have ever played, like any trem though, its all in the setup.
If you dont like it, take it to a professional and have it setup first before you do anything that isn't reversible.
Just my 2 cents
Old 01-22-2013, 04:02 AM
iced_ink  is offline
Posts: 107  -  iTrader: (4)
They have the same specs post to post measurements wise.They are after all from the same maker.They share the same knife design-1 fixed(curved) knife and one straight knife edge.
The issue will be the extra space the Gotoh Floyd will need.
The JS is routed for Edge trem's symmetrical base.The Gotoh's base is wider on the right side where you put the bar.
Old 01-22-2013, 01:59 PM
Thank you for the information shared.
Regards,
AK
Old 01-22-2013, 04:23 PM
jb4674  is offline
Reviews: 18
So, what exactly is the problem you're experiencing with the Lo-Pro?
Jimmy
Old 01-25-2013, 04:42 AM
None besides it's got a considerable amount of wear. I just thought to try the Gotoh (read lots of good feedback about that bridge) along it wasnt a complex process.
Regards,
AK
Old 01-27-2013, 05:23 AM
themaidenmaniac  is offline
Posts: 392  -  iTrader: (0)
The gotoh 1996 destroys any Floyd rose on the market. I know, I've played them all lol
There is a man on youtube who has done this to a js100- have a search. There is some routing needed but it can be done fine.
Old 01-28-2013, 12:18 PM
Thanks for the feedback!
bridge, gotoh, js 1000, neck
1996 Maple Super Wizard RG550 Neck Gojira Classified Ads: Guitars and Gear 6 02-21-2013 11:50 PM
F/S: Schaller Bridge/Gotoh Tuners/Kramer Body/Neck/Seymour zstarter Classified Ads: Guitars and Gear 3 08-23-2011 11:32 PM
WTB: Kahler 7330 Bridge or Gotoh 510 Wraparound Bridge X2N2 Classified Ads: Guitars and Gear 0 07-24-2009 07:41 PM
WTB: Bridge Gotoh TZ6 gold Ivygilbert Classified Ads: Guitars and Gear 0 01-17-2007 01:32 PM
Ibanez Fixed bridge specs (rg421) gemini8026 Other Ibanez Guitars (including Premiums) 8 01-16-2004 08:32 PM
