Old 08-13-2003, 06:58 PM
MoT  is offline
Posts: 5  -  iTrader: (0)
Need replacement nut for my chromeboy
The fifth and sixth string part of the nut on my chrome boy just will not tighten... One more millimetre would do it as most of the threading is intact. Is there a way around this without replacing the nut (or putting lighter strings on)? I use a 36 and a 46 for the top two strings.
If I were to replace the nut, where can I order one online?
What's the specs on the nut on the chromeboy?
Helllllp!!!!
Old 08-13-2003, 07:01 PM
Rich  is offline
Depends on how many threads you have from the bottom of the bolt, you can get a longer bolt and grind it down to maybe grab an extra thread or 2, if you have the room between the bolt and the wood. Otherwise I have 10th nuts in stock.
Old 08-13-2003, 07:10 PM
MoT  is offline
Bolts
I just need a longer bolt by the looks of it. The threads near the surface just aren't gripping. I'd need 1-2mm longer on the bolt to go through to hold the strings in place.
Do you ship to outside of the US? I'm in Ireland
Old 08-13-2003, 07:11 PM
Rich  is offline
Hardware store. I only have factory bolts.
chrome boy
