Old 10-22-2008, 03:16 AM
Valhalla  is offline
Posts: 130  -  iTrader: (0)
Optimal pickup heights - JS 1200
Just wondering what in your experiences has been the best pickup height for both the neck and bridge pickup in the JS 1200...
Old 10-23-2008, 03:33 AM
Valhalla  is offline
Re: Optimal pickup heights - JS 1200
Anybody?
Old 10-23-2008, 09:38 AM
GuiltySparc  is offline
Posts: 68  -  iTrader: (0)
I believe the pickup height question is "whatever sounds good to you." Not very helpful i know, if i remember i'll take a measurement of mine when i get home. Though i have a mo joe in the bridge rather than the fred.
Old 10-23-2008, 10:08 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
yeah, there are no universal measurements in pickups height, in the same model guitars neither. the rule of thumb is: not too close to the strings, but not too far neither. too close is about less than 2mms, and too far starts from about 4mms, measured from the top of the polepieces to under the strings, while fretting them at the last fret.
Old 10-23-2008, 10:28 AM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Here are the basic rules to follow:
- Closer = more output, less dynamics,
- Farther = less output, more dynamics
- Too Close = false/warbly tone up the upper frets and with some pickups you will actually lose sustain.
- Too Far = weak output
You can also tilt the pickup (bass side lower than treble or vice versa) to balance out the overall string response and if you're really pickup, you can adjust the height of the polepieces (assuming they are adjustable) to balance the the output between strings.
Old 11-16-2008, 05:38 PM
TKO Ken  is offline
Posts: 157  -  iTrader: (0)
[quote=toneboy;867902]Here are the basic rules to follow:
QUOTE]
That's it , no wonder you're name is "Toneboy"
Old 12-08-2008, 10:11 AM
plugger  is offline
Posts: 112  -  iTrader: (0)
A certain amount of air between the pickup and the strings can do wonderful things. More critical on single coil pickups, but most humbuckers need to be "dialled in" to a certain extent as well.
Old 12-08-2008, 12:21 PM
toneboy  is offline
Some pickups, like the beloved Tone Zone, sound like poop if they're too close.
Old 12-08-2008, 03:34 PM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
well the mojoe in my js100 is pretty close to the strings. the evo sounds awesome close to the strings. my les paul is the only guitar that i have a little space in between.
Ibanez edge saddle heights? mike-o Gear and Equipment 2 09-29-2008 03:36 PM
string heights question.. son_of_zion Tech: Setup, Repairs and Mods 6 04-22-2007 12:14 AM
Pick up Heights gemini8026 Other Ibanez Guitars (including Premiums) 1 01-18-2003 07:35 PM
Pickup Heights genesis Tech: Setup, Repairs and Mods 8 01-18-2003 04:37 PM
Evo's pickup heights Dave Goodland JEM and Universe Guitars 12 12-13-2002 04:59 PM
