Old 08-05-2005, 10:20 PM
wastedyears  is offline
Posts: 11  -  iTrader: (0)
Question
Original Floyd Rose trem. for my js100?
Would an Original Floyd Rose trem. fit on my Js100?
Old 08-05-2005, 11:48 PM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
Re: Original Floyd Rose trem. for my js100
It should. I'd see if I could return it just in case, though.
Old 08-06-2005, 02:05 AM
Gilbertoblues  is offline
Posts: 32  -  iTrader: (0)
Yeah, it should. But id have to imagine an Edge or an Edge Pro would fit better(And are much better trems IMO).
Old 08-06-2005, 02:29 AM
do u no of any sites where i could get an Edge or an Edge Pro?
Old 08-06-2005, 02:55 AM
Ibanez Rules should have an Edge Pro in, and maybe an Edge. Edge's arent made anymore, just look on eba\/, Eba\/ should have both of those, id imagine.
Old 08-06-2005, 03:45 AM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Re: Original Floyd Rose trem. for my js100?
What year is your js100, is it pre 2003? If it's got the Lo TRS trem then you can swap it directly with an OFR putting in an Egde or Lo Pro Edge might work but routing maybe needed. Putting in the Edge Pro on the other hand seems to (from want I read) even more diffucult.
Regards
André
Old 08-06-2005, 04:54 AM
guitarshredder7  is offline
Posts: 610  -  iTrader: (0)
id do an edge pro imo
Old 08-06-2005, 02:50 PM
Regards
André
yea its 2003... it has a Edge Pro 2...
Old 08-06-2005, 03:45 PM
fettouhi  is offline
Then a direct swap with an OFR won't AFAIK. You might want to ask Rich what the option is.
Regards
André
Old 08-08-2005, 05:06 PM
red5  is offline
Posts: 2,639  -  iTrader: (0)
Or a Lo-Pro, depending what era it is obviously.
If it has an edge pro II, then the Edge Pro. If it has a Lo-TRS, then I feel sorry for you, at least until you put an Edge or a Lo-Pro on it!
Old 08-08-2005, 08:22 PM
Phillip  is offline
Posts: 223  -  iTrader: (1)
On guitar with Edge Pro II you have to do some routing and maybe filling old post holes. Cause Edge Pro will not fit on Edge Pro II guitars, and so Edge or Lo-Pro Edge. The routing and post spacing is different.
Old 08-09-2005, 06:55 AM
fettouhi  is offline
Yup, well said .
Regards
André
Old 08-09-2005, 11:28 AM
dex  is offline
Posts: 1,972  -  iTrader: (3)
The only bridge that would fit an Edge Pro II route is Schaller FRII bridge - all the rest will require some routing.
The posts are spaced and placed exactly where they are on all FR type guitars but the route itself is too small and iregular to accomodate anything else.
ilia
Old 08-09-2005, 01:27 PM
fettouhi  is offline
ilia
Cool, did you check .
Regards
André
Old 08-09-2005, 01:29 PM
Phillip  is offline
ilia
I read somewhere, that new Edge Pro and Edge Pro II have different post spacing than older Ibanez bridges. Even EP II has different spacing than EP.
To sort this out, someone has to measure it.
floyd rose, floyd rose trem, ibanez guitars, pro edge, trem plate, wilkinson trem
Floyd Rose into an Edge 3 cavity??? Flame_Virtuoso_6688 Other Ibanez Guitars (including Premiums) 20 06-20-2005 08:54 PM
Original Floyd Rose or Floyd Rose Pro? Fatal-Tragedy Tech: Setup, Repairs and Mods 3 08-03-2004 10:56 PM
What is the correct angle for a floyd rose trem? big h Tech: Setup, Repairs and Mods 9 04-24-2003 03:55 AM
EBMM JPM trem vs floyd rose thc303 Tech: Setup, Repairs and Mods 3 03-03-2003 10:24 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 01:06 AM
