Old 10-28-2005, 05:36 PM
mike2558  is offline
Posts: 314  -  iTrader: (0)
problems with JS1200
I just got an Ibanez JS1200 but it's being a bitch. I tune every string but then when I go back and play the E string as well as all the others, it's way out of tune. It's goes super flat after I tune it. and when I play the A string and I think B, it buzzes. I wanted to smash the guitar into a wall at one point but realized that would be a bad idea. Any help please.
and also, the knobs are really smooth, they fell loose to me. They dont twist that fast on my ESP, it is supposed to be like that or not?
Old 10-28-2005, 07:17 PM
pawel  is offline
Posts: 2,656  -  iTrader: (3)
Re: problems with JS1200
No idea about the knobs. As for the tuning, is it any different than the way strings go out of tune on any floyd bridge? It's normal for that to happen on floating trems, start with the lowest E, and tune towards the high E, leaving some space for the strings to go flat, i.e. tune each string a little sharp to allow it to go flat once you tune the other ones.
Use this link: http://www.ibanezrules.com/tech/setup/tuning.htm
Also, where exactly is the buzz? (near the nut, near the bridge, half way on the neck)
Old 10-28-2005, 07:34 PM
mike2558  is offline
I don't know where exactly it buzzes. It just does.
and I noticed my trem angle has gone way up for some reason.
FFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUCCCCCCCCCCCC CCCCCKKKKKKKKK
Old 10-28-2005, 07:50 PM
pawel  is offline
Ok, the trem angle went up because you tuned your strings, tuning up pulls a string, which in turn pulls the bridge upwards.
I would advise you to read what Rich says in the link I posted, and follow it from the very beginning. To adjust the bridge angle, just take off the trem cover and tighten the two screws holding the little claw thingy, you might want to loosen the strings to do that, so that they don't snap.
Ok, before i confuse mysef - do this, step by step.
1. Loosen the strings, tighten the screws that hold the claw until the trem sinks into the body
2. Tune up, like described in the link, the bridge will rise again
3. Adjust trem angle
4. Tune up
5. Repeat steps 3 and 4
Eventually you should get the trem angle and the tuning more or less right, fine tune with the tuners on the bridge.
Now, raise the action a bit by raising the bridge a little bit, you will need some hex keys, I think, I never worked with an Edge Pro, I don't think it has locking studs so you don't have to worry about it. If the buzzing is gone, lower the bridge a bit until you hear buzzing again - it should then come from one particular spot on the neck, that would be some indication of what to do next. If you raise the bridge until the buzzing is gone, and are satisfied with the action, you can just live it at that for now.
Welcome to the world of floating trems ;-)
Old 10-28-2005, 07:57 PM
mike2558  is offline
thanks pawel, I'm gonna go at it and hopefully figure this bastard out.
Old 10-28-2005, 08:10 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Im gonna be mean for a second. You obviously dont know how to tune a floyd equipped guitar. The first thing you should do and I suggest this for EVERYONE, is find a guitar teacher and or a friend at school or work who plays and uses a floyd rose on a regular basis, have them show you the ins and outs of it, dont just pay a fortune for a setup. The things are a major pain in the ass until you learn how to use them, and at that magical moment youll be in total love with the things
Old 10-28-2005, 08:19 PM
Andelusion  is offline
Posts: 1,373  -  iTrader: (4)
MikeohollicA don't worry, once your floyd's setup properly as long as you don't start using a different string gauge rest assured you'll only have to make minor adjustments in future.
Old 10-28-2005, 08:29 PM
mike2558  is offline
^I have a feeling the 9 guage string will break easily and then I have to start the process all over.
you're 100% right. I'm trying to figure it out on my own and I've read about it in my manual and on Rich's site. I better find someone though, that's a good idea.
Old 10-28-2005, 08:38 PM
damo7v  is offline
Posts: 1,150  -  iTrader: (10)
where are you mike? i'm in KW. bring it on over and i'll sort it for you.
Old 10-28-2005, 08:40 PM
pawel  is offline
That of course would be a good way to do it. On the other hand, as Andeluson said, it will only get easier from now on.
I've always done it myself, and it's been a royal pain at the beginning, but with time i figured the sucker out, and it realy became easy later on.
Old 10-28-2005, 08:50 PM
mike2558  is offline
went back to tried again = no success
I think I will just take it to Long & McQuade tomorrow and get them to do a set up for me.
I live in Burlington about 30 k south of Toronto. kinda far away :-/
Old 10-28-2005, 08:54 PM
damo7v  is offline
burlington? not far! just go up highway 6, then west on the 401 for a bit!
Old 10-28-2005, 08:57 PM
mike2558  is offline
how about you come here >:O
Old 10-28-2005, 09:06 PM
damo7v  is offline
you cover my fuel costs? got cold beer waiting?
Old 10-28-2005, 09:14 PM
mike2558  is offline
hmm well I did just spend 2 grand on the guitar... so therefore no money...
*continues to smash head on table*
wahh :'(
arm holder, bridge angle, david mccarroll, equipped guitar, floating trems, floyd rose, floyd rose bridge, locking stud, locking stud mod, locking studs, trem claw
Any problems with the JS1200 CA original from Ibanez?? greggmetal JS (Satriani Model) Ibanez Guitars 20 10-07-2005 08:48 PM
**** JS1200 scam. CrazyD JS (Satriani Model) Ibanez Guitars 5 09-27-2005 09:02 AM
Js1200 Tremolo Setup Help! Stoph JS (Satriani Model) Ibanez Guitars 2 08-11-2005 05:37 PM
Js1200 Tremolo Setup Please Help Stoph JS (Satriani Model) Ibanez Guitars 0 07-14-2005 10:08 PM
new trem problems...from a different perspective btweensunandmoon Tech: Setup, Repairs and Mods 11 05-13-2003 12:47 AM
