Question about JS2000
Discussion about JS (Joe Satriani Model) Ibanez Guitars
03-29-2003, 01:15 PM
prodigalson1
Posts: 17 - iTrader: (
First off, hello everyone, been a long time browser of this forum, just recently registered. To the point, for anyone who owns a JS2000, what are you using as a reference to balance the bridge. The manual says to set it parallel to the body of the guitar, but there really are no definitive straight lines to refence besides possibly perpendicular. Also, is it ok to screw down the fine tuners completley if I don't plan to ever use them? and being that I actually have them all screwed down now, why is it that the high and low E will only screw down so far?Multi-radius??
thanks
prodigalson1
Find all posts by prodigalson1
03-29-2003, 01:20 PM
cerealk
Posts: 2,428 - iTrader: (
Welcome to the forum!
Have you seen?
http://www.jemsite.com/phpbb/viewtopic.php?t=16617
you may find more info here
http://www.jemsite.com/phpbb/search.php
best wishes
Simon
cerealk
Visit cerealk's homepage!
Find all posts by cerealk
03-29-2003, 02:03 PM
prodigalson1
yeah, I've done all the searches, nothing really addresses what I am asking.
prodigalson1
03-29-2003, 02:30 PM
Posts: 19,350 - iTrader: (
Since the 2000 is a
fixed bridge
there is nothing to *balance*, but if you just want to set the
bridge angle
you can either look at a correctly setup Lo Pro, or, the bottom of the base of the FBLP is flat at should be parallel to the top.
03-29-2003, 03:11 PM
prodigalson1
just the guy I was looking for;rich, how about the fine tuner question, and FBLP?
prodigalson1
03-29-2003, 03:16 PM
Fixed bridge lo pro [why did I think I was going to get away without typing it]
Shouldn't matter with the fine tuners but check it's not throwing the bridge radius off.
03-29-2003, 03:31 PM
prodigalson1
yeah i think the tuners are consistent with the radius, because I can't screw the high and low e ones down all the way(without forcing), and the saddles themselves seem to be making a gentle u-shape(inverted). I think Satch screws them all down, no?
prodigalson1
03-29-2003, 03:35 PM
No, I think Satch would use it in the way it's intended
03-29-2003, 03:45 PM
prodigalson1
tsh :P the only reason I would think to screw them down is that I am not locking at the nut, and will never use them, so might as well be in the most even, secure, position possible. To be honest, I've never liked them, always seem to affect the feel of the strings. Thanks for all the help, my questions are answered....
prodigalson1
03-29-2003, 03:52 PM
In that case I'd just remove them [just pull the little plastic washers off the tips first]
bridge angle
fixed bridge
compare js1000 and js2000
QUESTION: what's the next number?? 1, 2, 6, 42, 1806, ? the 6th number is the password to the exce
06:43 AM
