Replace Cracked JS100 Neck with Jem neck
Discussion about JS (Joe Satriani Model) Ibanez Guitars
12-21-2006, 08:22 PM
ggl
Posts: 26 - iTrader: (
My JS100 (1994 black model) has a crack in the neck and I got it checked by a luthier who confirmed it is unrepairable so I need to replace it. I thought that placing a
Jem Neck
in it might be cool but I have read that you can only buy the exact same model neck from Ibanez and you have to send the old one in. I have some
pictures of my js100 here
of this.
Any thoughts on this would help, what would you do in a situation like this?
ggl
Visit ggl's homepage!
Find all posts by ggl
12-21-2006, 08:26 PM
Petie
Posts: 2,877 - iTrader: (
Re: Replace Cracked JS100 Neck with Jem neck
Bad idea even if you COULD get a Jem neck. Because the Jem neck has 24 frets and the JS has 22, they're different lengths. They're not designed to be interchangable.
Petie
Visit Petie's homepage!
Find all posts by Petie
12-21-2006, 08:27 PM
giannifive
Posts: 484 - iTrader: (
The crack is confined only to the area near the nut, right? If so, based on those pics it looks like it may be repairable. Check out Rich's tutorial at ibanezrules.com.
giannifive
Find all posts by giannifive
12-21-2006, 08:38 PM
jem_fanatic
Posts: 212 - iTrader: (
Petie
yeah you wouldnt be able to do it as intonation would be impossible due to the different scale length , sorry man
jem_fanatic
Find all posts by jem_fanatic
12-21-2006, 08:50 PM
dragsternj
Posts: 1,710 - iTrader: (
based on the pics very much repairable with actually not very much effort and evven less tools
dragsternj
Find all posts by dragsternj
12-21-2006, 10:24 PM
toneboy
Posts: 1,665 - iTrader: (
jem_fanatic
The neck may have different overall lengths, due the the total number of frets, but they are the exact same scale length (25.5").
toneboy
Find all posts by toneboy
12-21-2006, 11:06 PM
RSVampire
Posts: 1,813 - iTrader: (
toneboy
yup, you wouldn't have any tuning issues or intonation issues it's the fact that it has 24 frets vs 22. If you tried to put the Jem neck on the JS guitar the last 2 frets would run into the
neck pickup
. So to get it to fit you'd need to route a bigger neck
pickup cavity
to place the neck pickup towards the bridge more.
Also, the Jem neck has a AAJN and the bolt setup are completely different so to get it to fit you'd need to modify the body or modify the neck. IMO not worth it, buy an RG if you want that style or just buy a new JS100 or upgrade yourself to a JS1000.
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
12-22-2006, 01:58 AM
ggl
ok the feedback/ideas has been welcome from everyone....
giannifive
It does extend up towards the tuners slightly as you can see in the pics although the length of the split is not highlighted so well in the pictures. It's also split in three places (by the middle of the holes, top & below each hole)
I checked out that great tutorial on a split neck repair and it looks like I may be able to do this, it's worth a shot at least....
I have one question with repairing this, Would I have much problems putting the neck back on the the body again? I guess I will have to get the
truss rod
all set up correct plus all the intonation setup can get tricky....
With the Jem neck question, well I will have to forget that, it was just an idea.
My plan now after thinking about it is to try to fix it first and if that doesn't work too well then I will try to see if I can get hold of a neck on eb or maybe try to sell it this like it is as "needing repair" - I would most likely take out the dimarzios for my next guitar though...
ggl
12-22-2006, 02:11 AM
LethalAe86TypeR
Posts: 665 - iTrader: (
Ouch, what happened?
LethalAe86TypeR
Find all posts by LethalAe86TypeR
12-22-2006, 02:24 AM
ggl
LethalAe86TypeR
I'm not even sure, I do remember bumping it against a wall a few months ago so maybe it was that but I never noticed it until recently (about 3 weeks ago). Maybe it was just from the changing weather patterns here in Aussie?
I have been reading some other threads like this one
here
, it seems some people replace this neck if they want to improve it so maybe looking at another neck like the one used in the js1000 or an
aanj neck
( I have no idea what this is yet) could be an option if the repair job doesn't work.
ggl
12-22-2006, 02:46 AM
LethalAe86TypeR
ggl
here
, it seems some people replace this neck if they want to improve it so maybe looking at another neck like the one used in the js1000 or an aanj neck ( I have no idea what this is yet) could be an option if the repair job doesn't work.
AANJ= All
Access Neck Joint
LethalAe86TypeR
12-22-2006, 09:13 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
It really is too bad you can't just buy a neck from Ibanez direct without having to send the core.
Jimmy
jb4674
Find all posts by jb4674
dragsternj
ggl
I have one question with repairing this, Would I have much problems putting the neck back on the the body again? I guess I will have to get the truss rod all set up correct plus all the intonation setup can get tricky....
Taking it off an putting back on should not be a problem at all, intonation should not change and you may not even have to touch the truss rod.
dragsternj
12-22-2006, 10:53 AM
ggl
AANJ= All Access Neck Joint
ok I see now
yeah, I think they cost a fair bit as well but I guess sending the neck in is not a big deal and I would not need it again or do you mean I have to send the rest of the guitar in as well to verify I need one? ... at a guess maybe it would cost about $400 US plus shipping costs from australia to US could be another $100? if I was gonna buy a new one or replace the neck and spend any sort of cash like that then I would prefer to get a js1000 neck and what they cost is anyone's guess? If I did that and replaced the trem I would nearly have something as good as a js1000 since it has dimarzio's in it already and similiar wiring to the 1000. As for buying necks then I think using eb would be the best idea in this situation.
dragsternj
that's good to hear then, I will go shopping next week and find some suitable glue etc and get started and will be sure to update this thread on how it goes....
ggl
12-22-2006, 01:18 PM
Posts: 19,352 - iTrader: (
I have a JS1000 neck off a new guitar where the nut screw broke off in it. I've Dremmeled it mostly out but it still needs a little attention, in fact I'd have it thru drilled for a regular nut. In case you need.
aanj neck
access neck joint
jem neck
neck joint
neck pickup
pickup cavity
truss rod
parker are they neck thru
how to replace floyd rose with ibanez zr tremolo
paf pro vs evo neck?
how do you put the strings closer to the neck on a ZR tremalo
Jem Neck on Regular RG Body accident?
Societysucks
07:18 PM
Jem 7VWH neck question
blackfuneral
11:20 PM
Broken Jem 7D Neck - Help!
Fripp Logic
05:22 PM
to replace JEM neck where to get a new one?
Jare
02:18 PM
Replace neck
nicko
10:07 PM
04:44 AM
