Old 12-29-2006, 05:02 PM
staypuft  is offline
Posts: 7  -  iTrader: (0)
Setting up the Lo-pro for js1000
I can't use anything higher than .9s for standard tuning or the lo-pro rasies way too high. And if I move up to 10s, I need to tune a full step down. I've looked at every tutorial I could find and I still can't figure out why the Lo-pro raises so much. I have tightened the springs and made 2 of them diagnal in the cavity and all that. Am I supposed to keep screwing in the screws past the end of the ridges? I'm pretty sure that's a hint to stop screwing..(You know how they have like half an inch before the end? I don't know the technical term for that.) I can't think of anything else I could do. Does anyone have any suggestions?
Old 12-29-2006, 05:06 PM
Smitty  is offline
Posts: 841  -  iTrader: (1)
Re: Setting up the Lo-pro for js1000
You mean the lo-pro itself is tilted, and not action? If so, just keep trying. I restrung my js1000 with .10s and I love it, except that the action is still a bit high for me...
smitty
Old 12-29-2006, 05:12 PM
staypuft  is offline
Thanks for the reply. the lo-pro itself is tilted.
Old 12-29-2006, 07:30 PM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Take the backplate off and adjust the screws and see the toturial in the tech section at Ibanez Rules (banner above).
Regards
André
Old 12-29-2006, 09:43 PM
staypuft  is offline
I did.
Old 12-29-2006, 10:57 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
How are the knife edges? are they above or below the body?
Jimmy
Old 12-30-2006, 12:52 AM
Smitty  is offline
Good point. I say just try your best...youll get eventually.
Old 01-02-2007, 11:18 AM
kisuco  is offline
Posts: 33  -  iTrader: (0)
add another spring...
Old 01-02-2007, 11:45 AM
dannymills  is offline
Posts: 1,398  -  iTrader: (5)
The thing to do is to loosen the strings completely, tune the top few a few steps above their intended notes, then tune up the bottom strings. As soon as you tune one, the others go a bit out due to the tension change. To compensate for this, tune the guitar in sets, and over tune one set before tuning the other.
If you tune E to E, then A to A, then D to D, by the time you start on the top strings, the E and A are out. then you raise them, and the others are out. And you can keep raising them all you want, until your trem is as it is; very high! So just do try I wrote above.
Old 01-02-2007, 12:23 PM
Ke^in  is offline
Posts: 528  -  iTrader: (0)
The loPro and Edge will have a tilt. It's not FLAT like the EdgePro
If that is what you mean by "tilt"
Old 01-02-2007, 12:33 PM
AirGuitar  is offline
Posts: 821  -  iTrader: (5)
I've always added another spring when ive restrung with 10's on an Ibanez. My musicman worked ok with 3 springs, but ive always needed 4 with Ibanez.
Old 01-03-2007, 01:45 AM
staypuft  is offline
I added another spring but the cover that goes over the end of the springs (closest to the bridge) can't screw back on because the springs are in where the screws used to go.. Is that cover necesary?
Old 01-03-2007, 06:40 AM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
Exclamation
That spring holder thingy is necessary, otherwise when you pull up the springs will unseat from the trem block.
It will go completely out of tune, furthermore you may damage other things such as the knife edges (the trem could shift)
Old 01-03-2007, 08:04 AM
jb4674  is offline
Reviews: 6
Smile
That's not necessarily true. The block itself has a spring cover which in term is screwed into the block to prevent the springs from popping out. Even if you add one or two springs, you should be able to put the cover back on. Post some pictures and let us see how the bridge looks and how the back cavity looks.
Jimmy
Old 01-03-2007, 07:00 PM
eviltwin  is offline
Images: 6
Lightbulb
Jimmy
I think it was exactly that spring cover at the end of the trem block, that he was intending on leaving off...
trem block
Questions about setting up my Edge Pro trem billyboy Tech: Setup, Repairs and Mods 7 04-05-2006 09:55 PM
eventide H-3000S setting help needed Hartfolk Gear and Equipment 2 07-21-2005 06:09 PM
Setting up my guitar... Sam101 Tech: Setup, Repairs and Mods 2 07-15-2005 11:14 AM
RG570 tremblock setting knotty Tech: Setup, Repairs and Mods 1 04-23-2005 07:40 PM
Any problem setting up for BEADGB? - Any problem setting up Pudreaux JEM and Universe Guitars 2 06-28-2001 03:56 PM
