Tapping with JS1000
Discussion about JS (Joe Satriani Model) Ibanez Guitars
10-29-2002, 12:41 AM
untitledblinkfan
Posts: 19 - iTrader: (
Tapping with JS1000
Anyone find it kinda difficult to tap in the higher regions of the JS1000? Maybe its just my skill(read: lack thereof) at tapping, but for some reason I can tap better on my
FAT strat
than on the JS1000. By difficult to tap I mean getting the notes to sound. For example, like eruption type stuff(TAP 12, pull off to 5, hammer onto
I can get the 5 and 8 notes to sound just find, but the 12, 13,15, or whatever i can hardly hear at all. Any suggestions?
Thanks
Matt
untitledblinkfan
Find all posts by untitledblinkfan
10-29-2002, 01:18 AM
RSVampire
Posts: 1,813 - iTrader: (
Get some stronger fingers. That's all I can say...
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
10-29-2002, 01:22 AM
untitledblinkfan
Right on
that's what i figured...seems like they sound better when i use a pick to tap, so i guess the strong finger argument is a valid one. Mainly I waited to know if anyone had any trouble when they first got the JS1000 adjusting to it in ways similiar. ya know, thing you can do on one guitar don't always seem to work the same way on another.
untitledblinkfan
10-29-2002, 04:10 AM
sniperfrommars1
Posts: 3,302 - iTrader: (
Some guitars you need to have a little pull in your right hand when your tapping as well. You can get away with silly things on a strat sometimes cause of the weird tension. I often use a little reverb just to put accents on things when Im doing leads. You may want to check your intonation as well
sniperfrommars1
Find all posts by sniperfrommars1
10-29-2002, 08:55 PM
Drew
Posts: 4,538 - iTrader: (
is the action even, between the two guitars? if it's a lot higher on the JS than the strat, that'd explain your problem nicely, and would be nothing a better setup couldn't fix.
As for me, it's aproximately equal between the strat, 7620, and 2027- i mean, the two 7's seem a little harder because, given the two extra frets, the last frettable position is a little smaller than it is on the strat, but that's probably just illusion- from #22 down, they're probably about the same.
Anyone else have trouble tapping on the 24th fret cleanly? if i don't hit it perfectly, i get a dead note, and it's so narrow, unless i'me paying careful attention, it's easy to screw up. Not as bad as the (shorter scale)0 24-fret prs i screwed around on once (man, the last few frets were nearly unusable), but still...
-Drew
PS- for the record, i do have fairly big hands, so maybe i'm jsut being over anal...
Drew
Visit Drew's homepage!
Find all posts by Drew
10-29-2002, 11:26 PM
sniperfrommars1
well for one thing those frets are at the
neck joint
, a little bit of a difference in sustain, If im tapping in the second octave I try to use my pic or the edge of my fingernail to make things a little sharper and cleaner. What
gauge strings
do you use drew???
sniperfrommars1
11-09-2002, 04:36 PM
necromonicon
Posts: 45 - iTrader: (
thanks for saying that. I'm a tapping fan and I was thinking of buying a js1000. Well I think I'll not get it.
necromonicon
Find all posts by necromonicon
11-09-2002, 06:27 PM
sniperfrommars1
Honesty, joe has no trouble doing eight finger tapping on a js, I dont think most players will either
. Technique is often to blame not the gear
. Gear doesnt make anyone a better player but it can make you more comfortable with your creativity
sniperfrommars1
11-09-2002, 11:19 PM
RSVampire
I 2nd that sniper. Every guitar can play nice. If you can't tap....get some stronger fingers or set up the guitar a little better. Cause I've never had problems tapping on guitars....even with high gauge strings and action. Just devlop some muscles....and practice...that's all you can do
RSVampire
11-10-2002, 02:17 AM
spacenuke
Posts: 670 - iTrader: (
yeah, just keep practising and practising and practising. It's frustrating sometimes not being able to play a lick properly even a lot of practising, but just keep doing it and you'll eventually get it. oh yeah, and it's almost never the gear that's the problem.
spacenuke
Find all posts by spacenuke
11-10-2002, 06:40 AM
DrPuls
Posts: 123 - iTrader: (
I dont have a problem tapping... Guess just gotta get used to it huh..
DrPuls
Find all posts by DrPuls
11-15-2002, 10:22 AM
gwee_vine
erm...i have a feeling that it's either your guitar is set-up poorly...with the string height REALLY high....or it's your amp set-up poorly with poor gain....
IMHO a JS-1000 has incredible playability and whenever i teach my students.....even newbies can make the guitar sound......don't worry bout your technique....if you have to actually tap HARD to make your guitar sound.....it must have really weak pickups...
gwee_vine
Find all posts by gwee_vine
11-20-2002, 02:41 AM
Drew
9-42, plus a 56 b.
Yeah, th epick thing isn't a bad idea... and anyway, i'm just being anal, up through about 22 or so i have no problems, and even hit 23 and 24 pretty consistantly.
One thing that you might wanna try, matt, is to practice tapping onto a muted string in the upper register, and sustaining/vibratoing the note...like this:
e|-----t22~~~---|
this really helps you even out your tapping, and focus on getting a clean tap.
-Drew
Drew
fat strat
gauge strings
neck joint
WHAT is the difference between js1000 and js1200
how to keep a js1000 in tune
how to config the js1000 guitar
what amp to use with js1000
07:28 AM
