The best quality bridge for JS100 - Jemsite
Old 02-26-2014, 04:13 PM
bingooen  is offline
Posts: 4  -  iTrader: (0)
Hey guys.
So, i know its widely know that the low pro-trs sucks. Guess what. It does. I bought a used JS100 from 2009, and the knife edges are worn out, so OFC the tuning stability is like **** and i need a new tremolo bridge. My question is:
What is the best quality tremolo bridge for the JS100? As far as i have read its edge vs. original floyd rose vs gotoh floyd rose. I think most like edge the most. Also i want, if possible, to be able to swap it right in.
Thanks a lot.
Old 02-26-2014, 04:36 PM
kissTheApex  is offline
Posts: 519  -  iTrader: (5)
Re: The best quality bridge for JS100
Welcome to Jemsite!
I believe your JS100 should have the Edge3. Edge Pro should fit in without any modifications if you don't want keep the existing studs and stud anchors as Edge Pro doesn't have the locking studs either.
If you want to or willing to enlarge the bridge route to allow for the longer fine tuner extensions on FR or Gotoh, I would go with Gotoh as it can be had for quite less than a Floyd Rose Original at least here in the US. Ibanez's Edge/Lo-Pro Edge bridges are manufactured by Gotoh if i remember correctly.
Forgot to add, Schaller also known to be a very good brand and its fine tuner extensions are shorter than OFR, but I doubt it would fit in the Edge Pro opening either. Also, Schaller is the OEM manufacturer for OFR, again, if I remember correctly.
Old 02-26-2014, 05:31 PM
bingooen  is offline
I guess it's going to be a IBANEZ LOPRO EDGE. Saw this guy use it as replacement for his JS100 bridge. Seemed good and easy.
I think im going to buy this one, since im from Denmark: LOPRO EDGE gold from Thomann.de
Any thoughts would be appreciatet.
Old 02-26-2014, 06:55 PM
I'm not sure if a LoPro Edge will fit in Edge3 cavity without modification. i recommend you go to the tech, setup, repairs sub forum and read the Edge3 replacement thread (it should be a sticky).
Old 02-27-2014, 09:57 AM
bingooen  is offline
Im sorry. Its a guitar from before 2003. Its for sure a LOPRO trs 2 sitting in now. Im considering a LOPRO TRS for replacement. Other alternatives?
Old 02-27-2014, 05:26 PM
Not that I'm aware of but TRS should be a no modification fit if you want to use the same studs. check Jamvan's thread in this subforum, I believe he did the same thing you're trying to accomplish.
EDIT:i see you already visited Jamvan's thread
Old 02-27-2014, 05:57 PM
LonePhantom  is offline
Posts: 8,995  -  iTrader: (11)
Reviews: 120
It's a LO-TRS II, not LOPRO, doesn't say that anywhere.
Easiest switch is going to be the Japanese LO-TRS, since they are essentially the same basic design, albeit with far better construction quality.
Other than that, Gotoh licensed Floyd Rose, and a little sanding work around the cavity.
Old 03-01-2014, 05:48 AM
Marcel-JS-build  is offline
Posts: 8  -  iTrader: (0)
Gotoh GE 1996T will fit in a JS 100 but NOT directly... you have to modify the bolts that clamp the strings, the are to long and wil hit the body ... and I had to cut out some wood from the body and fill it at the otherside..
Old 03-02-2014, 06:37 PM
darrenw5094  is offline
Posts: 281  -  iTrader: (0)
Best value in top trems is the Schaller who also make the Original Floyd. The Schaller is much cheaper than the overpriced other top trems.
The Schaller, Gotoh, Original Floyd, Edge and Lo Pro all do a great job.
Old 03-05-2014, 09:02 AM
Petie  is offline
Posts: 3,152  -  iTrader: (0)
I like the Gotoh and Original Floyd. It will most likely take some work though whichever way you go, but it's worth it to get the most out of the JS100.
edge , floyd rose , gotoh , js100 , low pro-trs
JS100 BRIDGE question unseenforcez JS (Satriani Model) Ibanez Guitars 10 04-26-2011 03:12 PM
Ibanez Quality/ JS100 / S570DXQM erasetheprocess Other Ibanez Guitars (including Premiums) 11 01-28-2011 07:13 PM
JS100 Bridge Problems hylianhero27 JS (Satriani Model) Ibanez Guitars 9 12-19-2006 06:21 PM
Should I get a new bridge for a Strat or should I buy JS100? Xavier 7 JS (Satriani Model) Ibanez Guitars 1 06-10-2004 07:55 PM
Evolution bridge H into a JS100 Uglifruit Pickups & wiring 2 08-07-2003 08:16 AM
Powered by
