Closed Thread
Old 07-10-2005, 08:26 PM
jimbojim  is offline
Posts: 82  -  iTrader: (0)
Tremsetter with JS1000BP
would they work fine?
anyone who has some please share your reviews
Old 07-10-2005, 08:57 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Re: Tremsetter with JS1000BP
Used one in a 7620 for a while - it depends what you're trying to do. It'll kill flutter and won't hold you in tune if you break a string, but it WILL give you in-tune compound bends while leaving you with a semi-floating trem (it's not true floating, as it gives you a zero return point, but that's sorta the point).
I've been running a Tremol-No in my PWH and now CST for a while, and while it won't give you in-tune bending while allowing you to use the bar, it'll give you a truely floating trem that, at a second's notice, goes fully fixed and allows you to screw with alternate tunings and not go out if you break a string. They should be on the market in a couple months now, so that's the other alternative to keep in mind.
Old 07-10-2005, 09:28 PM
jimbojim  is offline
thanks alot dude. Those pitch changes on adjacent strings when I'm bending are annoying sometimes.
Old 07-11-2005, 02:27 AM
HDS  is offline
Posts: 1,237  -  iTrader: (7)
Originally Posted by Drew
I've been running a Tremol-No in my PWH ........ They should be on the market in a couple months now, so that's the other alternative to keep in mind.
What's the price point going to be on them?
Old 07-11-2005, 10:48 AM
Drew  is offline
Haven't heard a hard figure, but I believe Kevan was shooting for $40-60 or so. Worth it - my prototype is built like a tank, and the final ones will actually have even stricter material tolerances (Kevan wasn't entirely happy with the surgical stainless alloy the shop that did the pre-production run used for the shaft - neither was the shop, for that matter, I think it ended up being a supplier issue).
Old 07-11-2005, 10:52 AM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
^^ please keep that discussion in the large tremno thread.
finally search "tremsetter".
closed... glen
Closed Thread
alternate tuning, alternate tunings
Tremsetter - Has anyone used one of these? rbjammin Archived Topics and Common Questions - GO HERE FIRST 9 03-18-2011 12:08 PM
floyd rose moves when bending a string bujecas Tech: Setup, Repairs and Mods 17 09-01-2008 07:46 AM
Tremsetter Shaker3 Gear and Equipment 12 05-17-2005 09:51 AM
tremsetter please help!!! guitario JEM and Universe Guitars 1 05-14-2005 02:45 AM
simple question about the hipshot tremsetter jeffrg270 Tech: Setup, Repairs and Mods 12 02-21-2004 01:47 PM
