Hi there and welcome to the forums.
Congrats on your new guitar!
If I understood you correctly, the string is in tune on the lower frets, but not on the higher ones..? If the tuning is just slightly off, there could be an intonation problem.
Check the 12th fret harmonic (just touch the string where the 12th fret is) and compare it to the fretted note there (push the string to the fretboard). Is the note roughly the same? If not, somethings wrong with your intonation.
You'll find almost everything you need to know about guitar problems here:
But a very good starting point is also the setup manual that
should have come with your guitar. (if it was brand new)
