Want to replace my old Low-Pro Edge trem
Discussion about JS (Joe Satriani Model) Ibanez Guitars
07-04-2003, 08:05 AM
karibou
Posts: 9 - iTrader: (
I want to replace the old Lo-
Pro Edge tremolo
on my JS1000 by the new Edge-Pro double-
locking tremolo
. Are they available as spare parts
(nothing related on the Ibanez official website)
Karim
karibou
Visit karibou's homepage!
Find all posts by karibou
07-04-2003, 09:08 AM
EXCrosslink
Posts: 164 - iTrader: (
the edge pro has a different routing so i don't think you can drop it in as it is, there is very little difference in feel between both so unless you're having problems with the old bridge, leave it as it is
EXCrosslink
Visit EXCrosslink's homepage!
Find all posts by EXCrosslink
07-04-2003, 02:06 PM
Posts: 19,352 - iTrader: (
Not interchangable. The saddle inserts on the EP force the routing back about 3mm+ making it unintonateable if you tried mounting it on LP stud location.
07-16-2003, 05:00 AM
karibou
What's the Lo-Pro Edge JS Special ?
So Lo-
Pro Edge
tremolo and the new Edge-Pro double-locking tremolo are not switchable... no luck.
Another question regarding Edge and Lo-
Pro Edge trems
which are switchable :
What is the difference between the Lo-Pro Edge "JS special"
http://www.ibanez.com/parts/default....2LE1JS37K.html
and the standard Lo-Pro Edge tremolo ?
http://www.ibanez.com/parts/default....s/2LE1R31.html
karibou
07-16-2003, 05:25 AM
EXCrosslink
js lo pros come with the radius shims i believe to match the bridge radius to the js
neck radius
. i don't think there is any difference otherwise
EXCrosslink
07-16-2003, 08:26 AM
gitarrero
Posts: 577 - iTrader: (
Compared to the "standard" Lo-Pro, it seems to have a longer block which is 37mm (is this the "S" block?).
gitarrero
Find all posts by gitarrero
07-16-2003, 09:07 PM
I think the 37 is the H block, S block should be 34, the HS is 31. A JS should have an HS block on it, and near all of them do. I consider anything else a mistake
07-17-2003, 04:41 AM
gitarrero
So the reason for the punched back plates on some JS's (see my other thread) might be that Ibanez ran out of HS blocks, installed longer ones and made a hole in the plate to retain pull-up capability.
gitarrero
07-17-2003, 11:38 AM
The hole is just "standard" on 92' and 93' models [yes even the ones with the correct block]
edge trem
edge trems
locking tremolo
neck radius
pro edge
pro edge trem
pro edge tremolo
pro edge trems
what trem is on the rusty cooley
how to replace clutch of ford focus zetec
how to replace floyd rose with ibanez zr tremolo
can you replace the edge zero bridge?
04:24 AM
