WHY WILL MY JS NOT STAY IN TUNE?!?!
Discussion about JS (Joe Satriani Model) Ibanez Guitars
04-19-2007, 08:14 PM
Smitty
Posts: 841 - iTrader: (
Ive had my JS1000BP for a little over a year, and its been giving me trouble from the start. I switched from 9s to 10s, and that helped it stay in tune a little bit, and I changed from 3 springs to 4, and that helped a little too, but its not enough. No matter what brand of strings I use, how much I stretch them, whether I use the arm or not, etc, it goes out of tune quite quickly. Too quickly for an Edge Pro. When I screw on the
locking nut
after tuning, the guitar goes out of tune. Some strings flat, others sharp. This does not make sense to me. And then, once I fine tune it (which is VERY annoying, because I have to fine tune it so much from the beginning that I dont have much tuning room until the next time I tune...) it goes out again. I bolt down everything perfectly, I have intonated it, I have checked the neck bow (perfect), set up the action and
bridge angle
(perfect) and it still will NOT STAY IN TUNE. I am very pissed and will hopefully sell it tomorrow for a prestige S. But I would still like to know if anyone has had any problems like this. Its really quite a mystery that I would like to solve and avoid in the future.
smitty
Smitty
Visit Smitty's homepage!
Find all posts by Smitty
04-19-2007, 08:38 PM
Dee
Posts: 8,514 - iTrader: (
Re: WHY WILL MY JS NOT STAY IN TUNE?!?!
Does the trem cause the tuning to go sharp after pull-ups on the bar? It sounds like you already checked the obvious stuff.
By the way, the strings going flat or sharp when locking the nut is usually caused by the string
retainer bar
. Try screwing it down some more.
Dee
Find all posts by Dee
04-19-2007, 09:13 PM
S-man
Posts: 1,757 - iTrader: (
That's probably the root of your frustration.
I always have to tweak the tuning after locking down, but not that drastically. There is always plenty of room left on the fine tuners after locking down.
So adjust that string tree!!
S-man
Find all posts by S-man
04-19-2007, 09:34 PM
S-man
Side note... I can almost always run 10's on a 3 spring trem, sometimes it requires the arrow pattern for an optimal setup.
Your guitar was originally setup for 9's which just further complicates matters.
Changing
string gauges
to "fix" other problems usually doesn't work in the end. Though it can "mask" problems.
If I could give one piece of advice to the floating trem newbie....it would be...don't change the gauge of your strings until you get familiar with the floating trememlo system.
I'm not implying anything about the orignal posters tremelo knowledge...
Why do people insist on changing things before they sort out the stock configuration? I will never understand this. After all, 9-42's are the most commonly used gauges for Standard tuning. Rant off.
S-man
04-19-2007, 10:28 PM
David McCarroll
Posts: 2,049 - iTrader: (
Check that the Locking nut is tightly bolted onto the neck - the tuners also - I set up an RG 570 for a friend, and both the locknut and ALL of the tuners were loose! There was absolutely no way that guitar would stay in tune as the nut actually rocked back and forth as you used the trem! While you are at it, check that the
neck screws
are tight, and that there is nothing (including the ground wire to the trem claw) binding anywhere against the bridge or the springs - again, instant problems with returning to pitch.
Also suggest the Rich Harris trick of a little chap stick on the knife edges for lubrication - it all helps! If you are having problems with one Edge
equipped guitar
, swapping for another is most likely not going to solve your issues by the way!
David McCarroll
Find all posts by David McCarroll
04-19-2007, 10:31 PM
David McCarroll
Oh, one other thing - did the guitar stay in tune okay when you first tried it? Did the problems start to appear when you first changed the strings? If so, my guess is that you are not locking either the bridge clamps or the locknuts down quite tight enough. They are ALL fixable, so don't give up too soon!
David McCarroll
04-19-2007, 10:50 PM
Smitty
Thanks guys. The help is greatly appreciated.
Im definitly not new to the Floyd Rose (original, Ibanez, etc...all of them) and Ibanez. Ive been playing Ibanez Floyds for almost 3 years now, and 1 year and a boring rainy day is all thats needed to know the things inside and out.
I changed the string gauge a month or two after I bought the guitar. Ive never liked 9s much, theyre just too damn tiny, and of course heavier strings generally stay in tune better. And like I said, it did help, but only a bit.
Everything is bolted down nice and tight. Tuners, locking nut, saddles...except maybe the
string retaining bar
The string
retaining bar
and the knife lube sound like the most obvious solutions now. Ive tried everything else. And who knows...maybe Ibanez just screwed up on one guitar? But nonetheless, Im getting rid of it anyways. Now is the time that I try to make a name for myself, and playing a signature model wont get you very. And I like the S series more anyways
Like I said, thanks alot dudes. Now I know what to look for in the future.
smitty
Smitty
04-20-2007, 12:38 AM
Dee
Good luck man, I hope you get a solid guitar that you like. I agree with you on the sig model thing too. If you're carving your own identity, playing a
Joe Satriani
model ain't gonna cut it, as good a guitar as it is. They're for fans, hence why I choose RG over JEM.
Dee
04-20-2007, 12:48 AM
OLIE_ROCKS_THE_80'S
Posts: 2,770 - iTrader: (
Reviews: 10
To me it sounds like your guitar might not be set up correctly or you have the typical stud issue that the
edge pros
have! I would have adviced you to keed your JS and had a real pro set up your guitar but whatever makes you happy!
OLIE_ROCKS_THE_80'S
Find all posts by OLIE_ROCKS_THE_80'S
04-20-2007, 06:05 AM
PeteO
Posts: 18 - iTrader: (
My JS1000BP low
edge pro trem
gets a good whanging and the guitar just stays in tune! Fantastic guitar. I agree with Ollie, get a pro to set it up.
PeteO
Visit PeteO's homepage!
Find all posts by PeteO
04-20-2007, 07:40 AM
nuno
Posts: 4,725 - iTrader: (
often (very often)
locking nuts
would NOT rest firmly in place even if you tightened its screws a lot. i use to fill the gap between the locking nut and the "head" of the fretboard, with folded brass foil. you can spot the gap when you depress the bar, by looking closely at the nut-to-fretboard contact point, better with a light behind.
nuno
Visit nuno's homepage!
Find all posts by nuno
04-20-2007, 01:13 PM
shogun
Posts: 1,525 - iTrader: (
go to the setup page and fly through the checklist
shogun
Visit shogun's homepage!
Find all posts by shogun
04-20-2007, 01:14 PM
shogun
sounds like its ur string retaining bar being too high.. the nut is pulling the strings down
shogun
04-21-2007, 05:40 PM
Smitty
Lowered the string retaining bar, and I simply re-set it up, and now it works like a charm
But, I have been recently debating whether or not I like floyds in general, and they just arent for me. Im gonna sell/trade the guitar, for anyone thats interested.
It works perfectly now!! Woo!
Thanks alot guys. Youve been a real help.
smitty
Smitty
04-22-2007, 04:31 PM
Dee
Glad to hear it.
Dee
body shape
bridge angle
edge pro trem
edge pros
equipped guitar
fixed bridge
floyd rose
joe satriani
les paul
locking nut
locking nuts
neck bow
neck screws
retainer bar
retaining bar
string gauges
string tree
trem claw
how to stay on relic
how to tune lo-trs
does the JEM 7 trem stay in position?
when using tremolo bar tune is bad
WHAT KIND OF GUGE DO I NEED TO TUNE TO DROP A?
Floyd Rose without a locking nut...will it stay in tune?!
Smitty
01:00 AM
How can i make the lo pro edge trem stay in tune?
kalashnikov
32
02-01-2006
06:27 AM
Wont stay in tune
dohdoh
Tech: Setup, Repairs and Mods
10:02 PM
My new JEM7VWH won't stay in tune :(
excellentrocker
01:29 AM
how can i make my real floyd js bend notes in tune?
mikeyCOA
01:07 AM
06:57 PM
