Zero Resistance
Discussion about JS (Joe Satriani Model) Ibanez Guitars
07-20-2006, 08:50 PM
johnboy30230
Posts: 91 - iTrader: (
Zero Resistance
i would like to make a mod to my js1000 like the Zero Resistance
tremolo system
does anyone have any suggestions.
johnboy30230
Find all posts by johnboy30230
07-21-2006, 01:54 AM
johnboy30230
Re: Zero Resistance
how about a tremsetter? would i still be able to do dives up and down or will that fix the bridge.
johnboy30230
07-21-2006, 02:06 AM
jimbojim
Posts: 82 - iTrader: (
Re: Zero Resistance
I would like to know that as well
jimbojim
Find all posts by jimbojim
07-21-2006, 05:47 AM
Andelusion
Posts: 1,373 - iTrader: (
Re: Zero Resistance
A tremsetter doesn't fix the bridge unfortunately, it merely stiffens up the tremolo.
I'd suggest looking at a tremol-no which can fix the bridge, allow it to only dive, or be fully floating.
Andelusion
Find all posts by Andelusion
07-21-2006, 12:28 PM
guitarsalad14
Posts: 383 - iTrader: (
Re: Zero Resistance
A ZR trem would require substantial routing. Best look at another option ;o)
guitarsalad14
Find all posts by guitarsalad14
07-21-2006, 04:00 PM
johnboy30230
Re: Zero Resistance
i was checking out some vai stuff turns out he has a setup aclled the
ibanez backstop
. however they dont make it anymore or something but esp make something similar rich used to sell it but he says hes out it was some thing like an arm adjuster
johnboy30230
07-21-2006, 07:25 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Re: Zero Resistance
Actually the tremsetter can be adjusted to its highest point of tension and the bridge is almost fixed (the bar is also almost unusable at that point)
sniperfrommars1
Find all posts by sniperfrommars1
07-22-2006, 02:04 PM
guitarsalad14
Re: Zero Resistance
johnboy30230
i was checking out some vai stuff turns out he has a setup aclled the ibanez backstop. however they dont make it anymore or something but esp make something similar rich used to sell it but he says hes out it was some thing like an arm adjuster
Yea the
esp arming adjuster
will solve the non return to neutral when you yank and dive the bar and also provide counter tension for in-tune double stop bends.
guitarsalad14
07-22-2006, 10:11 PM
johnboy30230
Re: Zero Resistance
im not trying to fix the bridge i like being able to go either direction with my whammy bar however im looking for more stabability so i can change tunings with out having to readjust the bridge everytime
johnboy30230
07-23-2006, 12:59 AM
Ozzdoc
Posts: 1,008 - iTrader: (
Re: Zero Resistance
Just try getting better at restringing and try finding new tricks etc...then it won't be such a tedious task, rather enjoyable for some strange reason
Ozzdoc
Find all posts by Ozzdoc
esp arming adjuster
ibanez backstop
tremolo system
zero resistance trem
how to tune a zero resistance bridge
ibanez zero resistance tremolo how to guide with pictures
how to check pickup resistance
how to resistance of my speakers
DC Resistance and Millivolts
BiggieAL
Pickups & wiring
11:45 AM
output vs DC resistance
amateur_guitarist
Pickups & wiring
11:08 PM
Powersound Dc resistance
rickyk
06:16 PM
Need DC Resistance numbers for V2 pickup!!!
freewheeler
Pickups & wiring
12:28 AM
Volume & Tone Pots - Measuring the resistance? (or whatever
bduersch
Tech: Setup, Repairs and Mods
01:18 AM
10:24 PM
